You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
or
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones
HARD RESET:It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
•Enter the code: *#7370# and press Yes to confirm initialization.
•Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
•To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
•on/off + * + 3
•Before making a Hard reset better backup all your important information: contacts , memo...etc
Nokia 301
IMEI 1:352356068233345
IMEI 2:352356068233353
Help me please
IMEI 351744068199130
SOURCE: nokia
i m not sure if this is gonna help but still u can try reformatting it maybe it will change the code back to 12345 just press answering button,1,3 and * and while keeping these 3 buttons pressed just keep the starting button pressed at the same time.don't leave the buttons until "reformatting" appears on the screen.best of luck
SOURCE: forgot password
You have to flash your mobile to get rid of your old security code and this can be done only through any of the mobile service centers only.
SOURCE: i forgot my dell vostro
Go over to www.bios-unlock.com get a new password generated from your service tag #.
SOURCE: forgot my password nokia e5
go to home screen n press *#7370#
the phone will then ask for a lock code
thedefault is 12345
the phone will then restart
all data one the phone will be deleted so remove the memory card
hope his helps
John
