Do I need to take to a la Pavoni dealer to keep my warranty or can I go to a third party thanks, Barbara
SOURCE: no pressure
The relief valve has a toggle inside that is heat activated. This can stick. I found if you tap it with a spoon the toggle will release and the valve will close.
SOURCE: MY Triton T90si electric shower
Most conventional showers have brass seats or rubber seats that can deteriorate over time. these will leak or dribble and not maintain your temp.. Rubber and brass seats are a fairly common and easy replacement. It sure beats trying to rip out a shower valve.
SOURCE: Grohe 24'' Relexa Shower Swivel Hand Shower Holder broke!
Try going to this web page and looking up the nearest parts carrier in your area.
http://www.groheamerica.com/t/25_3859.html
sanray
SOURCE: shower head dripping cant turn shower knob off
Mixer valve needs repair. special tools required.
SOURCE: Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Testimonial: "Thank you so much for your help! Will try it out - your instructions are clear and sound do-able! "
Hi if you mean when you pull a coffee the grinds are coming out of the basket , then my first guess would be the grid is far to fine. If you mean coffee and grounds are escaping around the top of the portafilter then there is a problem with the seal, it could be it is not being tightened enough when you put it in or that it is dirty or faulty. Grid and tamp is crucial with these machines and it can take a bit of time and experimentation to get the hang of the balance. There are videos on youtube and on coffee forums that may help.
