Question about Dell Computers & Internet
Dell ST2420L monitor shuts off after a few minutes of use
I have a ~6 years old Dell ST2420L monitor, which has suddenly started showing this weird behavior: it will shut off completely after 3-4 mins of continued use - even the LED power indicator at the base goes off. Then it will come back again after ~7-8 mins, and then stays on again for ~3-4 mins. From this, it sounds similar to this thread [http://en.community.dell.com/support-forums/peripherals/f/3529/t/19505287], however in this case, if I only connect the power cable, I do not seem to have a problem - the monitor stays on. Also, after the monitor shuts off, if I power cycle with some gap ~20 secs, it again start working, at least for the next 3-4 mins. Can the experts here have some suggestions about what is going on here, and what can be done to fix this? Can this be a driver issue?
    Sergeant:
  • Dell Expert
  • 445 Answers
Bummer time to replace it power supply is bad or when it gets hot it will shut off. I had a monitor that would come on and go off within one minute. the montor was bad
Posted on Apr 24, 2019
SOURCE:
SOURCE: HP mx705 17 in.CRT Conventional Monitor vertical goes bad
it seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
Posted on Jun 26, 2007
freetek
  • 5569 Answers
SOURCE: 52" Samsung DLP
It is unlikely that you can do anything yourself.
It sounds to me that there is a power supply problem that has steadily gotten worse and that cannot be confirmed remotely, it must be done on site by an equipped professional.
Posted on May 21, 2008
SOURCE: Dell Optiplex gx280 shuts down and orange power light blinks
It happens because the power supply is overheats and computer goes to standby. The power supply is 160w or lower. Specially it will happen if you put more devices in such as video card or sound card. So the only solution you have is to place a small 1or2 fans toward the power supply to make it cooler. And 1 more thing the power for the fans should come from other sources.
Posted on Dec 29, 2008
SOURCE: Magnavox 50" plasma Won't Power on/Shut's off/Blinking red LED
The above fix, listed by Tom saved us!! We did as instructed and took off the back of our 50 inch Magnavox plasma tv. We were not sure what we were looking for so we googled capacitator (image) & there was a photo of a fried capacitator! Sure enough we noticed ours were "fried", we took out the board and went to an electronic supply store, bought the 2 capacitators ($2.00 each!!) and then found someone who did tv repair to sauter the new capacitators onto the board. (It is important someone who know how to sauter and recognizes polarity do do this for you) All in all we fixed this following the above instructions for $34.00 and our time. For a month we were told to spend hundreds getting a new power board!
Kudos to you Tom & thanks so much!!
Posted on Feb 02, 2009
SOURCE: Dell E173FP Monitor Problem
My Dell E173FPc exhibited this same problem as described by many people on this site. Having looked through the solutions I decided to investigate further.
Posted solutions point to a faulty 12V smoothing capacitor, dry joints on the inverter transformer or faulty driver transistors. All these were Ok in my case, but on closer inspection a dry joint was found on L202 – see picture.
Cleaning off the old solder and re-soldering fixed the problem.
So if your monitor exhibits the same symptoms carefully inspect all the solder joints of large components around the inverter.
Posted on Feb 10, 2009
Desktop shuts down abruptly but will restart without problems.
best start looking into a cooling fan problem .
Mar 16, 2015 | Computers & Internet
Speaker in/speaker out not working
Are you feeding the monitor via an HDMI connection? HDMI carries digital audio as well as digital video signals. If using DVI or VGA to connect it to your PC, there is no audio being fed to the monitor, so nothing can come out, unless you have a separate audio cable running to the monitor as well from the computer :o)
Nov 11, 2013 | Dell ST2420L 24 inch LCD Monitor
Dell 18.5 LCD out of range connet to tv tuner Problem video
Have you recently changed your monitor check the aspect ratio of TV tuner and monitor they should be of the same type,If you are not getting my point Let me know the manufacturer & Model of both the devices
Aug 07, 2013 | Dell ST2420L 24 inch LCD Monitor
Tv tuner connect flat
Please check if all the cables are properly connected. Press the auto button on your monitor to let monitor adjust settings automatically. Then set the resolution to default recommended settings.
Monitor doesn't turn on
1ST CHECK POWER CORD.
2ND CHECK CONNECTION ON BACK OF PC
3RD HAVE YOU INSTALLED, DELETED OR REMOVED ANYTHING FROM YOUR PC PRIOR TO THE MONITOR SHUT OFF ON YOU
Feb 17, 2013 | Dell ST2420L 24 inch LCD Monitor
Dell monitor st2420l wall mount
There is an adaptor bracket that you can purchase that replaces the stand. The only place so far that I have found it is a website called Gladiatorjoe.com. I havent purchased one yet bit it seems it would work
Aug 02, 2012 | Dell ST2420L 24 inch LCD Monitor
Monitor shuts off during use
3 years old and generally rated as a Mediocre monitor to begin with, I'd say I'd invest in a new monitor
Here are some replacement options:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010190020%201309821311%204017&name=%24100%20-%20%24200
Sep 10, 2008 | BenQ FP72G+ 17" LCD Monitor
Monitor not powering down
Do you mean the computer is sutting down but on the monitor showes different colors if so you might have a problem in the system you might have to reinstall you OS if the computer does shut down but the monitor stays on and flashes different colors you have to shut the monitor down manually with the power button on the monitor.
Feb 14, 2008 | Dell Dimension 3000 PC Desktop
Dell 17inch LCD Display - Blank
Hi, My name is Todd and I'm a customer advocate at Dell's corporate headquarters. My team helps customers via blogs, forums, and other tech sites online. You said the monitor is 2 years old. Do you have the original order number still? Depending on how you purchased the monitor it may have up to a 3 year manufacturer warranty and I may be able to replace it if it is within that warranty period. Please email me at Customer_Advocate@Dell.com if you can locate the order number and I'll be glad to see if its still under the manufacturer warranty. Include my first name (Todd) in the subject line of the email so it can quickly be routed through to me, and include the order or customer number if you have it. Thank you, Todd Customer Advocate Dell, Inc. http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Apr 25, 2007 | Dell E173FP 17" LCD Monitor
Open Questions:
Computers & Internet Logo
Ekse
Clive
Clive
