Cars & Trucks Logo
irene chamberlain Posted on May 17, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
98 diesel Jetta TDI rebuild engine won't start
Joe Stanton
Level 3:
Genius:
  • Cars & Trucks Master 1,154 Answers
  • Posted on May 17, 2017
Joe Stanton
Level 3:
Genius:
Answers
1154
Questions
5
Helped
315668
Points
3584
Did you bleed the injectors, water separator. fuel filter. Is the fuel pump running. A Chilton manual would be a handy trouble shooting guide. Diesel fuel injection is complicated and expensive ( Bosch).
My 2002 vw jetta diesel tdi had a recent oil change and I just checked the oil and it is way high. If I drive it will it mess the car up? I have driven it already but I'm really worried.
If it is grossly overfilled it can damage the engine as well as **** oil into the air cleaner and then the engine, on a diesel this can cause a run away engine because a diesel will burn the oil like fuel.
1helpful
My 2001 volkswagon diesel engine locked up after revving all the way up for no reason and the mechanic i talked to said it might be a timing problem do i need a new engine
if it does not turn over you may have seized the engine, so in answer to your question is yes..
it is usually cheaper to replace your engine then to rebuild existing....
good luck
3helpful
4answers
Do I need any special tools or wedge to change a timing belt for 2001 tdi jetta diesel.
Timing Belt Spanner Wrench
AST tool# H 2587-1
- Used for the Adjustment of the Timing Belt
- Applicable to 2004-2005 VW Golf, Jetta Pump Duse and 2002-2005 Audi 3.0 V6
Used for the adjustment of the timing belt.
2009 Suggested user price: $52.67
Assenmacher Specialty Tools
1 800 525 2943
AST tool# H 2587-2
- Used for Adjusting the Timing Belt Tension
  • Applicable to 1999 and later VW Golf and Jetta, Passat and 1999-2003 VW Beetle with 2.0L Gas Engine and 1.9L T.D.I. Diesel Engine
Used for adjusting the timing belt tension and is comparable to VW tool# T10020. Applicable to 1999 and later VW Golf and Jetta, and 1999-2003 VW Beetle with 2.0L gas engine and 1.9L T.D.I. diesel engine.
1 800 525 2943
128947643
1helpful
3answers
2000 Jetta TDI: How do I change spark plugs on 2000 VW jetta 2.0...
You're in the TDI (diesel) solutions section so it uses glow plugs.
If it's a petrol engine 2.0L then it would be accessible above and below intake manifold using a swivel spark plug deep socket.
2000 VW Jetta TDI when starting vibrates (felt under the break pads) and a really rough sound when starting and turning the engine off. I have had people tell me that this could be due to timing...
It sounds like a diesel.. They vibrate like ****, it's just what diesel's do. . Otherwise I'd check engine mounts, if they are worn, then the engine could be sitting down on the frame of the car making you feel ALL of the vibrations.
1helpful
2answers
My diesel engine on my VW TDI Jetta is having a hard time turning over. It takes forever to start and seems to be getting worse.
Have someone replace your fuel filters ($$$) and put a bottle of "Lucas Diesel Additive" available at Advance Auto Parts $8
P.S. If you have PREMIUM Diesel available in your area (BP-Chevron) run that for a couple of tanks.
Good Luck
Engine torque settings VW lt 35 1993 2.4 turbo diesel. Code ACL
bob go to collsionrepairadvice.com and I will send the download to you its a big file
Volkswagen jetta TDI engine locked up remove and replace engine
The only special tool I can think of is a big box of band-aides........
If you've changed a motor before then you know what you're doing.
Good luck, and make sure there are no kids around when you start cursing..lol
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
