Health & Beauty Logo
Lily Lily Posted on May 03, 2017
How to locate and replace a fuse or fuses in a Hoveround MPV5
  • ovidiu oprea
    ovidiu oprea May 03, 2017
    Hi Lily Lily, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
ovidiu oprea
Level 1:
Habit-Forming:
New Friend:
  • Contributor 18 Answers
  • Posted on May 03, 2017
ovidiu oprea
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
18
Questions
0
Helped
8972
Points
49
Here is te user manual to replace the battery where you can also find the fuse:
https://www.hoveround.com/Hoveround/media/Document-Library/how-to-install-batteries-for-mpv5-mk3-power-chair.pdf
Hoveround MPV5 Power Wheelchair. How to fix 4 flashing lights on an MPV5 Hoveround.
Question edited for clarity.
Page 53 of the manual refers. When in doubt, it's a good read!
4 flashes: The right hand motor has a bad connection
https://www.hoveround.com/media/wysiwyg/pdf/MPV5-owners-manual-rev-U-0718_8-20-18.pdf..
Is there 1 fuse in a hover round mpv5-mk3
SP12-35 NB (12 V 35 AH) batteries are available online, replace both at the same time.
link copy and paste
https://www.hoveround.com/media/wysiwyg/pdf/how-to-install-batteries-for-mpv5-mk3-power-chair.pdf
3answers
Hoveround MPV5 Power Wheelchair. What batteries do I need for my MPV5 Hoveround please. I want to get the correct batteries.
Easy to fit and easy to buy.
Hoveround MPV5 Wheelchair Batteries (Replacement)
Battery Sharks https://www.batterysharks.com > mpv5_b12-35_x2
The Hoveround MPV5 wheelchair requires 2 batteries - SP12-35 NB (12 V 35 AH). Please note that you need to use all existing cables and hardware from your ...
US$110.98 · ‎In stock
12V 35Ah SLA Battery Replacement for Hoveround MPV5
Walmart https://www.walmart.com > 12V-35Ah-SLA-Battery-R...
Product details · ML35-12 SLA is a 12V 35AH Sealed Lead Acid (SLA) rechargeable maintenance free battery, Pack of 2 - UL Certified · Dimensions: 7.76 inches x ...
Assembled Product Dimensions (L x W x H): 7....
Assembled Product Weight: 48 lb "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 62px;"> Rating: 4.3 · ‎6 reviews · ‎US$149.99 · ‎In stock
Replacement Batteries for All Hoveround Power ...
ezmobilitybattery.com https://www.ezmobilitybattery.com > hoveround-whee...
Hoveround · Hoveround MPV4 Power Wheelchair Replacement Battery (2 Batteries) · Hoveround MPV5 Power Wheelchair Replacement Battery (2 Batteries) · Hoveround ...
Hoveround MPV5 12V 35Ah Battery (2 Pack)
Raion Group https://www.raiongroup.com > hoveround-mpv5-12v-...
This Raion Power RG12350FP mobility scooter battery pack is a direct OEM replacement for your existing Hoveround MPV5 batteries (12V 35Ah).
US$119.95 · ‎In stock
Wt is the tire psi for mpv5 middle tire
The pressure is 50 PSI, but 45 PSI worked better for me.
Where are the fuses located
The fuse should be on the wiring harness by the battery connection.
1helpful
Online owners manual for Hoveround MPV5
The full manual is not available online. It must be purchased directly from Hoveround for $20 plus shipping. Please call 800-964-6837, you will need the serial number from your power chair, located inside the manual brake release above the footrest.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
