SOURCE: Soney 32" flat screen tv. 2006
Try going into the television, and changing the audio setting to stereo, it sounds like it set to SAP (second audio program).
SOURCE: c++ problem BGI ERROR
The most probable reason why the program is not working is because your Turbo C++ BGI Graphics folder is not "c:\\tc\\bgi".
Correct the path and it should work.
If you're sure that your path is correct, press Alt+F5 and paste the error received.
SOURCE: A problem caused theprogram to stop working correctly. Windows wi
Your problem is a little hard to say. Have there been any power outtages or has you computer been powered-off rather than the regular shut-down procedure. Windows registry and programs can be thus corrupted.
Also computer viruses can disrupt programs so please run for example
Mcafee's free online anti-virus to rule-out a virus problem.
http://us.mcafee.com/root/campaign.asp?cid=45694
Even if you have an anti-virus installed, it needs to be running the latest virus definitions.
You could also try in programs accesories system tools to select "system restore" and bring back your computer to a date where you understand the problem was not happening. (Try this one last)
SOURCE: Quicken launcher has stopped working, how do I
This will occur if you have any very long security symbols -- it happened to me when I entered some of the new option symbols which can run 20 characters or more. I did not check to see exactly how long they can be but editing the security list and reducing them to 15 characters or less solved the problem.
SOURCE: Why does silverlight program lock up computer?
This may not be your problem, but I have a client who has a webcam attached to his PC in New York, and when he inadvertently accepted the Microsoft Silverlight download as a part of Microsoft Windows Updates, his camera no longer worked and his computer froze-up. Removing Silverlight solved the problem, so there was some sort of driver conflict with the webcam. Never found a solution thru either Microsoft or the camera manufacturer's website.
