I suggest you can approach Theunlockarena.com and specify the country,locked network of Nokia E71.Based on the availability you can get the permanent unlock service along with free instructions.
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: nokia 6110 unlock code
Hi, willimina your IMEI: 354847011991730
mastercode:
764454375x
The mastercode can be entered instead of standard security code.
and
Hi, LucasMok your IMEI: 357666019013793
mastercode:
461072065x
and the other users please let me know your IMIE number for unlock any phone.
please do not forget to rate this solution if it works.
and Thanks for using FixYa.
SOURCE: i want to unlock my nokia e71 IMEI =
i forgot my security code plz tell me his solution my model is nokia 6233
SOURCE: unlock code for my Nokia E71
Switch on the phone
Press *#7370#
Enter the default code "12345" when requested
OR
Make sure your phone is switched off.
Press the keys "3", "*" and the green/talk button simultaneously. This
action forces a hardware reset and also reformats the device
Without releasing the 3 keys mentioned above, press the "on" button.When you feel the phone vibrate, release only the "on" button but not
the keys in step 3.When you see the Nokia boot up screen (handshake screen) then you can
let go of all the keys.
www.usedcellphoneshop.com
SOURCE: unlock code for nokia e71-1 my phone has been
Welcome to Fixya
If the phone is still under contract or not with Optus. Only optus can give you the unlock code for your phone. Other option is by using third party unlocking sites. Please check this link. Take not that this site are not free.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SOURCE: unlock nokia e71-2 rm-357 straight talk
Hello friend, you can unlock your mobile by using the codes..This is the safe method..I found an unlocking service at Unlocking4u.com .Through this you can unlock your mobile easily..
