Tablets & eReaders Logo
A
Ann Schwatken Posted on Apr 07, 2017
Can I replace the battery to my ipad myself or do I have to send it in?
Can't send emails on my ipad
see if this helps you out..
To resolve this you need to alter the port that your iPhone or iPad uses to send mailwhich can be done as follows. Go to Mail, Contacts, Calendars and select the account you wish to change. On the next screen, scroll down to the "Outgoing Mail Server" section and select the SMTP server that is listed.
Why can't I send mail from my iPhone or iPad? - Knowledgebase ...
customer.maginternet.co.uk/.../65/Why-cant-I-send-mail-from-my-iPhone-or-iPad.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Can't+send+emails+on+my+ipad
My RCA tablet wont charge I have to lean it against something to charge WHY??
Help! My tablet won't turn on! what do I do?! - Asus - Android ...
www.tomsguide.com/forum/id-1869519/tablet-turn.html
Oct 17, 2015 - 50 posts - ‎43 authors
We often get questions such as " My tablet has stopped charging & I have .... Maybe the case was designed badly and the power button won't ..... Something must havelocked the Memopad open and ran the battery completely down. ..... I had RCA send a replacement tablet after it happened the first time.Missing: lean
Why can't I get my RCA tablet rct6077w2 charge or turn on ...
forums.androidcentral.com > Get Help & Give Help! > Ask a Question
Oct 8, 2014 - 4 posts - ‎1 author
Screen will not light up at all. Took it to store, got brief charge there. At home, now, no indication of power.....Missing: lean
How to Calibrate Your Mac, iPhone, or iPad Battery ...
www.macblend.com/how-to-calibrate-your-mac-iphone-or-ipad-battery/
Mar 14, 2012 - The iPad and other tablets draw more current to charge quickly then a lot of other USB devices ..... Also, it's not something you should have to do frequently. ... iPad 2 will not charge shows battery in red with electrical symbol and plug symbols flashing on ..... I'd lean against trying to restore if it won't stay on.
My samsung galaxy tab wont charge at all, why? - Ask Me Fast
www.askmefast.com > ... > Charge
2answers
IPad will not charge even though battery and charge port both replaced.
Incorrect port part, Wrong polarity for wires connected to the port or poor connection of wires to the port.
How do I reset my emails so it just sends emails to people and not give you a copy
Go to settings / Mail, Contacts, Calendars then find Always Bcc myself and switch it off.
My Apple iPad 4th Generation will not charge when plugged in. What should I do?
My ipad has done this twice. Both times it has been due to the battery going totally dead and a bad charger cord. Take it to a radio shack or to someone and have them to use one of there chargers wait a few mins. See if it begins to show any signs of taking a charge at all. It may take 20 mins. or so. If it doesnt then you will more than likely have to replace the battery inside the ipad. There have been some ipad batteries that havent lasted very long. Good luck and I hope this helps you.
1helpful
My iPad has a lock on it beside the battery sign how I can remove it so I can send emails
You probably locked the screen rotation,
to fix this:
  1. Rotate iPad so the display is in the desired orientation.
  2. Double-click the Home button to display recently used apps.
  3. Flick from left to right along the bottom of the screen.
  4. Tap the Screen Rotation Lock button on the bottom left of the screen.
  5. The lock will disappear
1helpful
How can I improve the battery life of my new iPad? It drains faster than iPad
I just answered this for someone else. You can see how to improve your battery life here.
Since I'm nice I will post here too.
  • Turn down screen brightness
  • Don't play graphics heavy games
  • Turn off location services
  • Quit applications you are not using
  • Turn off push notifications
  • Set email to manual update
  • Don't use 4G internet connection if possible
Ipad will not power up
Does its battery is full or not? Try to charge it then turn on it, if not work, suggest you send it back to Apple , they will be helpful. Or get a new table pc if it was damaged.LOL
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
