Network Connections
I'll give you a generalized answer because I am not familiar with the tablet you are using. The the principle is the same for all wireless devices. Go to their version of SETUP for wireless networks (for example, on the IPAD it looks like a gear symbol) and select the right network which will be chosen from a list they provide of nearby networks. You need to know the name of the network you're trying to get on. Don't try to type it. Select it from the list of available networks. When you do, it will most probably ask for the network password or key which you need. If you don't know it, then you need to find it. Sometimes it is on the base of the modem. Type it in carefully noting the caps and don't mix up zeroes and letter O, etc. It sounds like a password problem you are having so do this carefully. If it does not work, and If you use the network for your phone also, you can try logging the phone off the network and then logging back on with the password you think is right to confirm if it is a password problem but... if the password you are trying is wrong, you will now not be able to get your phone back on the network until you find the right password. Then you will also know how to fix the tablet log on as well. Hope that helps.
