Philips 50P8341 50" Rear Projection Television Logo
Posted on Jul 23, 2009
Power light comes on, then blinks 6 times, then off for 2-3 secon
Continually switches from 6 blinks to off for 2-3 seconds, the 6 blinks, etc.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
197
Points
You need a new Naftakey bord part number 313501707611.
Its your volume, channel and your on and off button that needs to be replaced you can do this yourself. Remove the front cover it just pops out and unscrew the back cover disconnect the wire to this area on the part it self it states "part number and name". Good Luck, in getting this part. Im having trouble in getting this part (discontinued item) They may have under another name part.
I have a Sony Bravia KDL-32XBR4 when I turn the tv on the green power light comes on for about 5 seconds with no picture or sound. Then the red standby light starts to blinking continually 6 at a time. Any...
mine did that once only to find that the source/input was on pc but there was no pc connected so it went into standby mode, i suggest turning it on and check to see that it is on the correct source/input.
WS-73513 Power light continually blinks and will not come on. Tried reset as in past but no success. Is if finally dead.
hold down 1st and third buttons from the right on the front of the tv for 5 seconds. The green led will blink then pause then blink again. Count the blinks . It will give a 2 digit error code . Let me know what code is.
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
3answers
Hi I have a TH50PZ80U that is flashing two red lights when I plug it in. If i press the power button for 5 seconeds it will flash 10 times. When applying power the AC relays click, after pressing the...
Hi bschaub796,
10 times blinking of your unit indicated that the processor sense the missing 15v from the power supply. This problem is quite technical since I've already read your post that you have a reading of 15v in P25.
Now, we have to examined it deeply to determine where the fault came from between the two board.
If you have a 15v coming from the power supply but its go to 0v after a while which trigger the 10 blinks, you have to check the feedback circuitry of the power supply for faults. If you can't find any faulty parts on that section means that the feedback circuitry trigger to shutdown because it sense fault in the D board.
Remember that it has a good regulation output from the power supply, the issue here is the feedback circuitry that sense the fault. If you are going to ask my opinion I've suspected that the fault is in the D board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
2answers
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Pushing on power button three green lights come on for one secone
click here you would find the details for led codes. you may select any laptop. codes remain the same.
2helpful
Light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
We had thunder storms my tv 65613 has a green blinking light wont star
Good Day,mikeybecerra; TV wont come on mb try these 6 items, please pay attention to the blinking light (it's a code) : 1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). LED stops blinking after 70 seconds of plug in but will not power on. 5. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 6. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001. Good Luck, big IRISH.
3helpful
3answers
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
