An E6 error code on a Belling induction hob typically indicates an issue with the power supply or the circuit board that controls the back two rings. Here are a few steps you can take to troubleshoot the issue:
Reset the hob: Try turning off the power to the hob for a few minutes and then turning it back on. This can sometimes reset the circuit board and clear the error code.
Check the power supply: Make sure the hob is receiving a stable and adequate power supply. Check the circuit breaker or fuse for the hob to ensure it is not tripped or blown.
Check the wiring: Inspect the wiring and connections for the back two rings to ensure they are not loose or damaged. Tighten any loose connections or replace any damaged wiring.
Contact a professional: If the issue persists, it may be a problem with the circuit board or control module. In this case, it's best to contact a professional technician or the manufacturer for assistance with repairs or replacement parts.
I hope this helps you resolve the issue with your Belling induction
Call a Wirlpool dealer and give them the code. They will tell you what the problem is. I think F5 or F6 is the control panel. The last time I went to replace one I was better off purchasing a new stove.
