Maximatic Deluxe Popcorn Trolley Popcorn Maker Logo
Posted on Jul 23, 2009
Elite Cuisine EPM 400 popcorn machine
Burner is burned out! Need to purchase a replacement
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2988
Points
24
Maximatic Deluxe Popcorn Trolley Elite Cuisine EPM 400 popcorn machine burner is burnt out. where can i find a replacement pot?
Anonymous
Level 1:
New Friend:
  • Posted on Nov 03, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2988
Points
7
We were sold an Elite Popcorn Maker (Model EPM-250) that does not work at all. I need a wiring diagram or schematic for this model, NOT the instruction manual.
There is no Service Manual and no Wiring Diagram, but the manual does have a link to the maker in California where you can ask. All it consists of is a two position switch (heater and light) heating element, stirrer and a lightbulb.
https://www.google.com/search?q=elite+popcorn+maker+model+epm-250+wiring+diagram
Where can I find a replacement wheel for the top of the popcorn Kettle for the Elite Cuisine by Maxi-Matic Model EPM-400? Our fell off and is lost.
That part, or any kind of substitute part is not sold in the USA. Return the machine to where you bought it if you can.
Heats up runs properly but not hot enough to actually pop kernels Elite cuisine by maxi max (r) Model No. EPM-400
Double check the corn measurements, and adequate power supply. Other then that you have to return it, you cannot repair that brand.
May I ask how much popcorn can the Elite Epm 250 Popcorn maker can produce?
The manufacturer rates it as a 2.5 ounce kettle. This means 2.5 ounces of raw kernels each batch.
1 ounce of kernels = 1 quart of popped popcorn.
Roughly a half gallon of popcorn every 3-4 minutes.
How much popcorn kennerls and oil do i add?
This is a 4oz popper. 1/2 cup kernels, 1/8 cup oil, 1 tsp popcorn salt in kettle per batch.
1helpful
Does not turn, keeps jumping
I got the same problem,so I disassembled the transmission box and noticed that the smallest cogwheel got stripped,but no one has given me a solution for that,they are machines made in china and neither nostalgia electrics nor any other company in the US sells replacement products.
6helpful
Elite Epm250 Popcorn Maker instructions
Turn on the heater and let heat for 2-3 minutes. The Elite EPM 250 popcorn maker uses a 2.5 oz kettle. This is for 1/3 cup of uncooked kernels. Add kernels with a tablespoon of popcorn oil (available in markets) and a 1/3 teaspoon of what's called "Flavacol". It's a seasoning that they use in movie theaters to add flavor, saltiness and color. It's available online (ebay) or at Smart and Final. Use this combo and you can't go wrong. For cleaning, let kettle cool, the add 1/2 cup water. Turn on kettle and let boil for 2-3 minutes. Then empty it out.
Where to get parts for a Elite Cuisine EPM 400 Popcorn machine?
Model EPM-400 Elite Popcorn Maker
Distributed by: MAXI-MATIC® , USA 18401 E. Arenth Ave. Building B. City of Industry, CA 91748 Customer Service Department: (626) 912-9877 Ext. 116/120 MON-FRI 9am-5pm PCT Email: [email protected]
Not all kernals are popping
Heat the oil longer before you put the kernals in.
Top Maximatic Kitchen Appliances - Others Experts
ELECTRICKSUSA
ELECTRICKSUSA
Thomas Perkins
Thomas Perkins
Are you a Maximatic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
