SOURCE: No AC from older Intertherm split system
It sounds like you are low on refridgerant. Double check to make sure both fans and the compressor are running. If so then you have a refridgerant problem.
Testimonial: "I left the feedback in the wrong place, sorry about that... I added it under my original question. I'm glad to say thanks twice, though! THANK YOU!!"
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
SOURCE: what does a df error
Friend!,
Please ensure with your model/brand and error code. To my knowledge and web search, I don't find tour model on market. Don't be angry, plz check once again and write back.
SOURCE: what does the error code
could not find the error code but I did find a manual, hope it helps Tim:
http://webshop.bauer-energi.no/PDF/Service%20Manual%20N12AWV_N09AWV.PDF
