Samsung UN39FH5000FXZA - 39in 1080p 240 Cmr Led Fh5000 Series Logo
A
Anonymous Posted on Mar 01, 2017
Samsung UN39FH5000F tv picture is no longer visible on the screen. I can however see the picture by using a flashlight. the picture is there, it is just not bright enough to be seen on the screen.
Grubhead
Level 3:
  • Samsung Master 5,755 Answers
  • Posted on Mar 03, 2017
 Grubhead
Samsung Master
Level 3:
Answers
5755
Questions
Helped
1662718
Points
11417
Watch this video.
https://www.youtube.com/watch?v=xUzCLgoSPGM.
It seems to suggest either a back-light or led problem.
My vizio tv has sound but no picture and already did the flashlight test
If your Vizio TV has sound but no picture, and you have already done the flashlight test, it may indicate that your TV's backlight or power supply is malfunctioning. Here are some steps you can follow to troubleshoot the issue:
  1. Check the cables: Make sure that all cables are properly connected between the TV and any devices you are using, such as a cable box or DVD player.
  2. Check the input source: Ensure that the TV is set to the correct input source that the device is connected to. You can cycle through the input sources using the input button on your TV remote.
  3. Power cycle the TV: Turn off your TV and unplug it from the power outlet for at least 1 minute, then plug it back in and turn it on again. This can sometimes resolve issues related to the TV's power supply.
  4. Reset the TV: Try resetting the TV to its default settings. You can find this option in the TV's menu settings.
  5. Contact support: If none of the above steps resolve the issue, it may indicate a hardware problem with the TV's backlight or power supply. In this case, you should contact Vizio support or a qualified technician for further assistance.
Samsung tv model #UN39FH5000F, versionPF03. Suddenly screen became so dark that the image was barely visable. Sound OK. Rebooted and reset tv, but no effect.
it could be the leds strips. one or more of the leds have gone. or there is a problem with the led driver board. could be a regulator or capacitors
The Audio and Video are two separate components and operate independently of each other. Therefore: The Video portion requires technical repair by a technician with the proper test equipment.
1helpful
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Samsung LCD tv model #un39fh5000f has no picture but has sound and can see picture with flashlight test, can you help
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
2answers
Samsung LED TV Model # UN39FH5000F Has audio but no video. No backlight is visible. Can't see "menu" with flashlight.
Its likely the panel itself or the digitizer is going out if voltage is flowing properly. If voltages are off then as I'm sure you know its the motherboard. Good Luck Friend!
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
