Lands Phones Logo
Pedro Torres Posted on Feb 22, 2017
29585fe1 GE corded phone beeps instead of ringing, how can I change the configuration tone?
Need some help out there! I just bought my 29585fe1 GE corded phone, the thing is when I receive a call, the phone beeps instead of ringing, and it's really anoying, is this normal? is there another possible configuration for the tone?...thks for ur help
1helpful
Dialtone but no ring only beep
Sounds like its either going offline maybe checking the outlet and the cord that plugs into the base. It may also be the battery needs replacing,it has been run down and charged again too many times.it may hold enough for a dial tone but not enuff to even ring,just beep I stead
I WANT TO BE ABLE TO ENTER NAMES AND PHONE NUMBERS IN THE DIRECTORY AND DESIGNATE SOME TO SPEED DIAL. I HAVE A GE FOUR LINE CORDED PHONE WITH CALLER ID SPEAKERPHONE AND INTERCOM
If you could also provide the exact model number of your GE phone, then I could certainly help you find the precise instructions for carrying out those procedures. Normally you should find the model number printed on the very bottom (underside)of the telephone.
Please just comment back with that additional information and I will be pleased to provide any assistance you need.
Thank you.
Joe.
Need manual for GE corded phone model 29585FE1
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/29585_DOM_ES_CD_IB.pdf
1helpful
INSTEAD OF RINGTONE, I GET A SINGLE BEEP
your phones alert tone was set to beep once, to change this go to profile settings then open the activated profile such as general>personalize>message alert tone then now choose the ring tone you want to use as message alert tone..
1helpful
2answers
Hell There, We have a "legacy" GE hands free kichen" phone model: 26730GE1-D Yes, I know it's ancient, BUT I did put a fresh, brand new battery in last week and it rings, when piucked up reads out...
Hi.
The calls are being placed on waiting, try using Flash button before using Talk.
Test the chance on a different phone line , the most likely is that the phone is defective.
If the phone is working on a different line, then it is a configuration problem, and the phone is waiting for a manual call transfer from a different phone in your network.
Try using Flash button instead of Talk, this will answer the call if there is a waiting service programmed.
Try testing with no other phone connected.
Finally try resetting the phone, use procedure below:
  • 1. Make sure the phone power is ON (but not in the “talk” mode by pressing the PWR button.
  • 2. Use the arrow buttons to scroll through the main menu until Handset setup is flashing.
  • 3. Press the SELECT button. A second menu shows on the display.
  • 4. Use the arrow buttons to scroll to Reset phone.
  • 5. Press SELECT.
  • 6. Use the arrow buttons to change NO to YES.
  • 7. Press SELECT to confirm.
If after resetting the calls are still being placed on hold, then again, the phone may be faulty.
Here a manual for your phone.
Jan 15, 2010 • Cell Phones
Beeps For message
You go to tone and press select and then u scrol down n select the message tone and then chang ur message tone as u wish.
by Zepa
Bhutan Telecom Ltd.
Bhutan
2helpful
Lost manual
I am having a problem with the language on my Ge corded speakerphone md#29585fe1.how do i change it to english. Thank you in advance.
Telephone ring tone
press flash on phone til you reach desired ring tone then pick up headset to set
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
