It is the flat spring that the thread goes under when you put the bobbin in the bobbin holder
however it very seldom needs adjusting as it takes just a very small movement of the screw to make a big tension adjustment
I suspect that you have bunching or birdnesting under the material and if that is the case it is the needle tension that has to be adjusted up
Generally, thread tension should be adjusted at the top thread. Only in extreme cases should the bobbin tension be adjusted.
http://www.singersewinginfo.co.uk/tension
How to Adjust Tension Sewing Machine
Liz Kettle adjusting your bobbin case tension 1 wmv
Fixing Top Load Bobbin
Sew What Up View thread Singer Stylist 513 threading correctly
