SOURCE: Epson C84 - no power
Most likely cause is the power supply has let go. It could be a fuse inside the power supply. You would need a servie manual to get you in to the machine to check if a fuse is present on the PSU. Try either of the following: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com (Join his list to see all the files available) Either of these should help you get a manual
SOURCE: Epson CX5400
change your printer adaptor & make sure that the input & output voltages & the current ratting are of the same value as the before.thanks.
SOURCE: Epson Stylus CS5800F Printer will not power on. Plugged into known working outlet, but no luck.
I had that same problem with my CX5800F. I tried it in several working outlets and shut down/started up many times. Tech support couldn't figure it out so they had me sent it back for a replacement. Several days later, before I packaged it up for shipment, I decided to test it out one more time, and it powered on! I sent for a replacement anyways. Since it's still under the 1-warranty, I'd suggest sending it back for a new one if all else fails. Good luck!
SOURCE: my epson c65 wont turn on at all. couple of days
Possible hardware failure, unfortunately.
Please disconnect the printer from all the devices connected to it. Plug it in directly to a working electrical outlet which means you have to bypass the surge protector. Turn it back on.
Please log on to epson.com. Go to drivers and support page and click on help me find a service center to the right of the page to find the local servicers near to your area.
SOURCE: POWER CORD AND CORD TO COMPUTER
1. You can find any Electrical Shop. Find 2pin power cord.
2. You can find any printer's USB Cable any computer reseller
Thanks
Sk. Abdus Sabur
