Toshiba Satellite Pro M10 Notebook Logo
Posted on Nov 20, 2007
Unlock bios password
How do i unlock a toshiba laptop m10 that has a bios password?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 19, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1095
Points
I have forget my bios password please help me on Hasee laptop
prabiyan
Level 1:
New Friend:
  • Posted on Feb 16, 2014
prabiyan
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1095
Points
I have toshiba laptop EQUIUM a100-306 how to reset bios password plz answer me
A
Anonymous
I have a problem with my acer aspire 5610 laptop, it developed operating system problem and in an effort to reinstall it started asking for a bio password. The system was bought brand new and no bio password was given at purchase. Please any solution? Any solution will be appreciated.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 20, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
1903
Points
9
What motherboard manufacturer?
You can try backdoor passwords depending on this.
You can call Toshiba, if you can verify ownership, and they will tell you the password to reset.
Bios of intel centrino 2 toshiba expose
You can look somewhere in the BIOS page to turn it off.
Toshiba use Esc and F1 key (it depends on the laptop's model), so you need to tap the Esc key or F1 key right after your turn on the laptop.
Clear bios password
try pulling cmos battery for a few mins
3answers
How to unlock toshiba satellite laptop BIOS and HDD
If you are the original owner Toshiba will reset the bios for a fee and it is not cheap, they may include the HDD reset, if not! www.ebay.com type password, or hard drive password. I would check bios password, probably a lot cheaper if you can find the right seller, also check www.download.com some software may be free.
Clear cmos password for toshiba tecra m10
Tough problem but you might get it to work with my hint:
http://www.fixya.com/support/r5953318-reset_bios_password
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Hi, I got a Toshiba Satellite Pro M10, Is there a way to remove Password?, i can not access to the O.S. (not even to the bios). Thanks
Yeah - if it's a BIOS password, but if it's a HDD password then you're screwed and there's nothing to do but replace the HDD.
For a BIOS password removal, either buy a parallel port password removal key, or make your own. Schematics can be found here: http://www.cgsecurity.org/wiki/CmosPwd.
Toshiba satellite Pro m10 power on password
If you power it on and get a "password=_" prompt, then it has a CMOS password set. The only known way around it is to buy or make your own parallel port key (aka parallel port password removal key - schematics are available free on the Internet) - which will clear the CMOS and set it back to its default state with no passwords.
I have forget my bios password please help me toshiba satelite pro M10
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove.
If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC
1helpful
2answers
My toshiba laptop is asking for a password it will not boot without it as soon as you turn it on it wants a password
BIOS is set to password on....
did anyone make changes to ur laptop....
if so then only he can unlock it....as BIOS passwords cannot be unlocked....they are embeded in the BIOS microchip...
only a BIOS update can undo it...and that's very RISKY...
Bios password reset for toshiba lap top
You need to build a hardware device that plugs into the printer port.
Get a 25 pin male D sub connector, and solder various wires
to the pins numbered below. The pins on the connector are numbered 1 to 25
For a picture of this hardware device (dongle) go to :-
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg
Connect these pins together by soldering thin insulated wires to the following pins :-
1-5-10,
2-11,
3-17,
4-12,
6-16,
7-13,
8-14,
9-15
Plug the dongle in the printer port and boot up the laptop, you will then be able to bypass the BIOS password and go into the BIOS to reset/remove the password.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
