SOURCE: i cant listen to music connecting my bluetooth
check out that is the phone's bluetooth is properly paired with the bluetooth headset if not check it
or
search for the bluetooth devices from the search list of the bluetooth devices in the bluetooth menu of your phone
SOURCE: How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
SOURCE: connection problem to phone light turns green instead of blue
Try resetting your headset by pressing power key and volume up key, until the LED flickers in different seqence. after a while try connecting with your device. it should work.
SOURCE: I cannot connect my 330 bluetooth to my phone, and I also cannot
Once you make your cell phone discoverable, then put the Plantronics
Explorer 330 into pairing mode by holding the call control button until
the headset flashes red and blue. Here is the link below for the
Explorer 320 user guide which has the pairing instructions, it will be the same for the 330.
Plantronics Explorer 320
Good luck from Headsets Direct!
Turn on the Bluetooth
In Bluetooth Off mode, press and hold the Bluetooth button for about 5 seconds until a beep sound is heard and the Bluetooth button backlight flashes blue.
Press and hold the Bluetooth button for about 7 seconds to change to
Bluetooth pairing (linking) mode. The Bluetooth button backlight will flash blue and red. then go to the Bluetooth settings on your phone and select it there and enter 0000 for the default password
Then go to the bluetoothT
