Brother DCP 1510 have Drum ! Massage clear corona wire but clean corona wire but no solve hove how to solve this massageBrother DCP 1510 have Drum ! Massage clear corona wire but clean corona wire but no solve hove how to solve this massage
You can't post conmments that contain an email address.
Hi try this press menu button hit down arrow until u see info on display press OK button hit down arrow until u see reset drum on display press and hold OK button until u see reset on display press start button press-up arrow until u see the value 10 press OK button on display should read accepted press stop until the main menu appear on display.......good luck
Try this: Clean the inside of the machine and the corona wire in the drum. If this does not solve your issue, replace the drum. Also, the paper tray ground terminal in the machine body may be dirty.Clean the contact with a dry cloth.
The problem is coming from drum unit . Clean the OPC of your drum and doctor blade (it is a brash which is situated upper side of the opc) and clean the corona wire to solve the problem.
The slides you are moving are for the drum units, you could try using canned air to blow in the same area that the sliders slide across, if that doesn't help you may need a new drum unit..
If you open the front cover you will have a grey/black part which is easily removed from the machine. This is the toner/drum package, where the grey part is the drum unit. If you look on the right side on the part of the toner/drum package that would go furthest into the machine, you'll see the corona cleaner, which you should move among the line (left to right) 7-8 times or similar. This should clean the corona wire and solve the problem.
Just put the corona cleaner back to where it started and re-insert the toner/drum package into the machine again.
I have a DCP 1510 so there is such a model
