I am questioning if main board is causing high voltage on power supply. I had also tried replacing power board, and this board read 115 VDC at LED + pin, but no 12 VDC or 24 VDC going to main board, so obviously bad. So before I buy another power board and main board, anyone know which component might be causing higher than normal 230 VDC which is same plugged in to LED strips or unplugged.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Testimonial: "I ordered and replaced inverter board, no change, picture is still dim pulsating while everything else works. Power board is separate on this model, so anyone know why voltage is 230VDC at LED+ point when it says on board it should be 157VDC for 42 inch, could it be the MAP3202 IC which causes higher voltage, or another component?"
