Because till u have alarm of configuration error in your system it won't accept the command it will always go into bypass u have to remove configuration error from ups system only then you are able to use ups system in online mode I can help u to fix it don't worry this is my WhatsApp number feel free to contact me Okk +919871039174
SOURCE: 97 gsxr600 no spark
This might sound dumb but I had a similar problem with my 05 750 tap the bottom of the ignition switch with a hammer or what ever you can get in there and see if that works, there are contacts on the bottom of the switch and on my mike they turn on the fuel pump and spark, I went through hell trying to figure it out and one day I decided to hit the bottom of it and the fuel pump kickied on, the cover on the bottom of the ignition was put on backwards and had loosened up, I switched it around and she runs great now.
SOURCE: alarm bypass. alarm system faulty
This had been done many times before.... But it is VERY involved and you HAVE to know what your doing. To bypass the little "chip" in the key, you have to know its resistance value in ohms, then you get a resistor of the exact same value and put it in-line in the wire that reads the chip in the ignition. Then you have tricked the system into thinking that the right key is always there. Like I said you have to know what wire it is, what kind of resistor, and what value to put in. However the payoff is no more expensive keys....keys without the chip will now start the car, sience you have tricked the passkey system into thinking the key has the chip in it.
SOURCE: how do I bypass alarm for 1994 buick lesabre
Yes ,I now how to do this I posted it earlier. March 1,
