GE JVM1350BW/WW/AW/SY Microwave Oven Logo
B
Beth Thompson Posted on Jan 15, 2017
Jvm1350 metal rack bracket broken-needs replacement -newer models list part as 1202, but bracket looks different
1 Related Answer
Everett
  • 27 Answers
  • Posted on May 26, 2012
SOURCE: My JVM1350 has metal rack inside. How do I use it. I thought you couldn't have any metal inside.
on the inside of micro.. the rack is supported with plastic clips.. this allows stock part metal rack work
2helpful
Door handle broken
Tony,
There are 11 different models that have this model number you listed, Need more information to answer your question correctly. In black WB15x10020, in almond WB15X336, in white WB15X335. I hope this helps as I looked up all the related models for you. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
I need to know if its safe to operate a microwave on a metal chrome wire shelf similar to a bakers rack which can hold 100 pounds per shelf
some microwaves are able to accepa a metal object others are not.
If your microwave ever came with a rack or a temp. probe made from metal then you can add a rack,newer microwaves bounce the microwaves better than older ones,thus the ability for the microwaves to bounce better.
Older microwaves direct the microwaves to a pinpointed center of oven, so what happens when there's metal in the focus area?
It bounces straight back to the transmitter which in turn over heats.resulting in a burnt out microwave transmitter.
good luck,Gary
2helpful
My Kitchen Aid Microwave Model no. KHMS155LBL 0 has a broken rack support hook on one side. There are four hooks which snap into a square hole on each side of the microwave cabinet to allow the...
The part you're looking for is Whirlpool number 8204662. Several sources came up from a Google search. Here's one. I've never done business with this site, but their price was the lowest of several I looked at.
One of the interior latches, or hooks,(rear) which hold the metal rack in place has melted and has begun sparking while the oven runs. Im wondering where to find a replacement and how to access the latch...
Ken, I have the same problem . . . I was told by the company that I need to replace the overn as the inside wall is burnt so it will happen all the time. . . have you found a soultion or heard any differently/?
1helpful
My microwave sparks inside where the metal rack rest on the plastic holder
You will need to remove the rack and all the rack holders.
Any grease or carbon arcs will have to be cleaned thoroughly, and if the metal is charred or damaged, you will need to apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
Then replace all of the rack supports, not just the one that arced.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
1helpful
I bought a used Kenmore Microhood, Serial # 302KM04866 and it does not have an installation bracket as did the "Spacesaver" I am replacing. I need installation instructions and, possibly, an installation...
You can find handy exploded views and part numbers at the Sears Parts Site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button (it may look different than this now, due to a recent site update). Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they may ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
26helpful
What size are t top mounting screws on the GE JVM1350 spacesave
You may be looking for the philips flat head 1/4 x 28 tpi (threads per inch) threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded hole in the top of the microwave:
General Electric's part number for their OTR microwave cabinet mounting screw is WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites).
A set of three is GE's p/n WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites).
This flathead screw is used on most Advantium Speedcook microwave ovens such as the SCA2001BSS03 or SCA2000FWW03 or SCA2001KSS03.
Here's a picture of three screws:
1helpful
GE JVM1190WY 003 Microwave Convection sparks
The problem that you are having is that the magnetron inside the microwave is shorting out to ground and it will find the shortest path to reach whatever has metal in it. Replacing the magnetron will solve your problem altogether and you need not do anything else different and continue using your metal racks.
2answers
Maytag Microwave MMV5207AAQ
its common to all ovens! causes are food spills and oil spills left uncleaned! painting only might fix the problem for a while, but it won't give you a lasting service!!
! you should buy a new rack for much safer use!
keep in mind also to clean the oven after every use! (let it cool first of course!)
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
