Vtech VT-IA5879 Phone Logo
Posted on Jul 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After buying a new battery, the phone constantly says Needs Recharging after 2 weeks on the cradle
Scharlie Meeuws
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 15, 2009
Scharlie Meeuws
Contributor
Level 1:
Answers
Questions
Helped
275
Points
How long is a phone battery running without needing recharging
Steve Brown
Level 3:
President:
  • Master 688 Answers
  • Posted on Jul 21, 2009
Steve Brown
Master
Level 3:
President:
Answers
688
Questions
Helped
394088
Points
2264
Take the battery back to the store and exchange it for another one, explain that the battery won't charge.
Or just buy another one.
1helpful
2answers
How do I stop the battery from draining after only a few hours.
try letting the battery completely die and recharge it. Do this 2 or 3 times. Sometimes "topping up" a partially charged battery puts a memory into the battery and it wont allow you to do full charge.. I let my Nokia get to its last legs before replacing the battery with a spare and then fully charge the other one. Both batteries are now at least 6 years old.. Yes , its an old phone...
1helpful
Battery last for few minutes (15-20minutes) for LG touch phone after recharging. What is the issue ? It's one year old. Too much texting ?
its not the texting but your battery had been worn out and it needs to be replaced. every cellphone battery has its life. try to buy a new original battery instead of replicas for your cellphone. it will really help a lot.
Nov 02, 2010 • Cell Phones
1helpful
Battery constantly needs recharging ( bought a new battery & still happens ) turns itself off,takes ages to turn back on, have to take battery out etc.
Your new battery, where did you get if from? If at your cell phone service provider's place of business - return it and have them make an adjustment. Please don't get insulted here ... If you bought it at "Cheap Jack's Discount Battery and and recycling Center", you probably got taken.
I'm sorry your phone doesn't work. I am pretty certain that a good new battery will solve your problem. While at your Service Provider, have them take a look at the phone to make sure there is nothing else wrong with it.
Thanks for your interest in FixYa.com
Jan 22, 2010 • Cell Phones
2answers
My phone's battery dies quickly
yes. your battery is worn out. if you want you could just buy a new one. or, if you have a phone contract as most do go to your phone company store and see if you are now eligible for a new phone at a low price.
2helpful
2answers
My Logitech Dinovo Edge is not recharging. When I put it in the charger the battery charging indicator light flashes red instead of green.
Were you having problems with short battery life before this happened? Most of the time if the battery is not recharging it needs to be replaced. Have never seen the red flashing light before though. It may mean that the battery has shorted out.
Battery or the camera cradel
Parts or a new cradle are hard to find. I don't think Fuji makes them any more, although, depending on where you live, that country's distribution source may still have stock. What we sell our customers is a small charger which recharges the battery outside of the camera. They are about $10 US and plug into the USB port on any computer.
7helpful
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
1helpful
Unit will not turn on
Check for voltage at the end that plugs into the cradle. If no voltage there, check glass fuse inside end that plugs into car plug. If there is voltage at the cradle end and it still doesn't turn on then it's the cradle. The cradle fails over a short time inside the cradle plug. You can hard solder the cable end to the cradle circuit board, which is a delicate procedure which I have perfected but I am an electronics person. If you want to buy a new cradle it will fix your problem for turning on the gps but I recomend a cable tie on the cradle cable end to stop the strain on the connector so the new cradle connector will last a long time.
Fuji f-401 not recharging.
There is only two possibility why the battery didn't charge.
1) cradle ( socket at camera side ) faulty.
2) the power adaptor faulty ( no dc voltage,can use volt meter to confirm ).
it worth repairing .Thks
IPaq rx3715 locked up
try leaving battery out overnight.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
