20 Most Recent
RCA WHP141 Consumer Headphones Questions & Answers
Can't get battery cover to turn
I placed a little vegetable oil around the lid using a toothpick to apply the oil. Wait a few minutes and the cover will come right off.
Can I hook up headphones to a computer, if so how
Simple, your PC should have a headphones jack, sometimes with a green ring around it.
Plug the headphones plug that comes out from your new headset base to it.
Its cable labeled 13
To a plug that looks like so:
best luck
Can't open battery cover
I sprayed silicone all the way around grove and waited about 5 min. than took palm and keept working it counter clockwise using pressure
No power.
check the TV volume. it must be aat least 50 percent or the phones will shut down after 4 minutes.
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Battery cover removal
I used WD40 on a paper towel spread in in the groove all the way around then used my palms one on each side of the ear peace to turn it and that freed it up.
