Amazon Kindle 1 Logo
J
Judy Lehigh Posted on Dec 12, 2016
Kindle Fire (1st edition) - "Stanley's kindle" (not tablet) will not turn on; light comes on briefly, then stops.Have charged and it hasn't helped.
Kindle Keeps Discharging Kindle Troubleshooting?
Very difficult to diagnose phantom discharging, but the most likely cause is just a worn out battery that is not holding its charge.
Kindle Tablet Repair - iFixit
https://www.ifixit.com > Device > Kindle_Tablet
Comprehensive set of repair guides for tablets developed by Amazon, under the name Kindle. Repair is generally pretty easy, and usually only requires... Kindle ...
‎Kindle Paperwhite 1st... · ‎Kindle 3 · ‎Kindle Fire · ‎Kindle 4
kindle repairs - Amazon.com
https://www.amazon.com > kindle-repairs > k=kindle+r...
Results 1 - 16 of 219 - Original Quality Screen Replacement for Amazon Kindle Fire HD8 HD 8 8th Gen 2018 L5S83A, 8Inch Touch Screen Digitizer + Full Repair Kit.
Amazon Kindle Repairs - Wireless Warehouse
https://wirelesswarehouse.ca > amazon-kindle-repairs
Amazon Kindle tablet so far has seen 16 generations or 16 models where ... all the industrial quality requirements are met in the repair procedure of the product.
My Kindle fire won't move past the start up "kindle fire" screen. what is wrong and how do I fix it?
Hello
Reset the Device:
If your Kindle Fire won't move, this doesn't necessarily mean that it's "broken" or has a major problem. The Kindle Fire has a tendency to become "stuck," meaning that it looks like it's "off" when it's actually "on" but it will not work properly because it's locked up. To unlock the Kindle Fire, do a reset by holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to get the Kindle Fire up and working again.
Charge It:
If resetting doesn't work, it's possible that your battery is dead. Try plugging the Kindle Fire into the charger and wait about 15 minutes before trying to turn it on again. If the device refuses to start up, try resetting it again.
If it still won't move, it's possible that you have a dead charging cable. Alas, the cables that come with the Kindle Fire are not known for their longevity. Try charging the tablet with another cord that has a Micro USB connection and see if the device responds. There's no guarantee that the charging cord from your smartphone will work with the Kindle Fire, but it's worth a try. If you get a bit of a charge, then you'll know that your Kindle Fire needs a new charging cable.
Try a Different Power Source:
if the charging cable appears to be working but the tablet still won't move, try plugging it into a different power outlet or the USB port on your computer.
If all of these troubleshooting tips fail, your Kindle Fire may have a hardware problem that requires professional help.
Visit here:
Kindle Fire Support
Can't get to work
Amazon has pretty good help, try starting at the following page to troubleshoot your problem or call Amazon Customer Service:
Fire Tablet and Fire Kids Edition Tablet 4th and 5th Generation Help
If you have just received it, make sure that the battery is charged before attempting to turn it on for the first time.
Good luck
2answers
My keyboard is not lighting up
Kindle keyboard is not lighting up
2answers
Kindle fire light cuts of after 10 minutes and it doesn't want to turn on
Held the button that turns the Kindle Fire on, and it will restart it, and the light should come back on. The only other suggestion is the "20 second" hard reset.
You can also give them a call at:
U.S. and Canada: 1-866-216-1072
Kindle Support: 1-866-321-8851
International: 1-206-266-2992
Why can't I turn on my Kindle fire HD 8.9 after I've been charging it overnight?
try another charger 1st so you can see if your charger is not working properly
2helpful
4answers
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
