Singer products range from basic sewing machines for beginners to complicated technologically advanced sergers and other machines that are used by professionals as well as...
The manual indicates the machine should be oiled approximately once a year and has a picture of where the oil needs to be applied. You can find your manual at the following location:
Try adjusting the tension. It sounds like the bobbin thread is too loose or the bobbin is not in correctly. Try taking the bobbin out and turning it around and putting it back. When you hold the bobbin in the fingers of your left hand and you pull the thread out with your right hand the bobbin should be turning clockwise. If the nesting persists, try ajusting the tension one way and then the other to see which seems to help. Hope this helps!
Make sure to thread machine with the presser foot raised. Then make sure thread gets in between the tension discs and that you have the machine threaded correctly with the thread going up and into the take-up arm. tension should be set at 4-5.
