Ptess tv then code input button then press the power button contiuously till it cuts off. Then hit tv again . It should be programmed
I have AD-UL101+S UNIVERSAL REMOTE. I NEED CODE FOR JAZZ TV
Have a look at the website for amley
see link here: http://j.gs/13861611/amely
Please am using Haier tv and I have Amely AD-UL028, How do I programme the remote for my tb
How can I use Amely AD-UD175 Remote control for my Samtel Receiver?
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
SOURCE: I need setup code for one for all remote urc 4063
SEARCHING FOR YOUR CODE
If your device does not respond to the
remote control after trying all codes
listed for your brand, or if your brand is
not listed at all, try searching for your
code. For example, to search for a code
for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED
blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing POWER and TV. Stop when
the TV turns off.
NOTE: In the search mode, the remote
control will send IR codes from its library
to the selected device, starting with the
most popular code first.
5. To lock in the code, press and hold
SET until the LED blinks twice, then
release SET.
6. To search for the codes of your other
devices, repeat steps 1 through 5, but
substitute the appropriate device key
for the device you are searching for.
SOURCE: i need 3 digit remote control signal code for a sanyo tv
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
SOURCE: DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
SOURCE: sanyo tv codes
lost remote for sanyo tv now have a G E universal remote and i need the code to work the tv
codes for sanyo are..
3digit codes:
004, 017, 021, 039, 048, 049,
056, 057, 058, 073, 080, 107,
162, 169, 180, 196
4digit codes:
1004, 1047, 1048, 1049, 1073, 1078, 1080, 1089, 1095
1107, 1121, 1129, 1162, 1163, 1169, 1180, 1196
