Cars & Trucks Logo
Justin Elliott Posted on Dec 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does the music from my Lionel train musical boxcar sound slow and warped?
Already tried a new 9volt battery, didn't make a difference.
Alan W Kelly
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 110 Answers
  • Posted on Dec 03, 2016
Alan W Kelly
Expert
Level 2:
Cheetah:
Answers
110
Questions
Helped
24883
Points
279
Whoah! Wow! Lionel trains! I'd like to see some images if you can take some and post them here. Best guess, blindly guessing, could be corroded metal conducting battery DC power. Could be broken wire conducting voltage. Could be a switch that is stuck. Could be a commuting wire that is out of place. A commuting wire is that which is attached to the train car and touches the track to pick up the DC voltage running through the track. Does that make sense?
Add photos if you like. If you are taking care, and using all your senses, you may determine the cause of the problem for which you are seeking an answer.
Have fun, and -- you are on your own, be careful.
VW Beetle 1.9tdi, Gets lots of slowing cranking, hard to start (Only sometimes) New battery, Gets P2100 and P2102 although new throttle body (But is only a anti-run on on a diesel.)
P2100 and P2102 refer to the Throttle Actuator not the Throttle body. This is basically the switch system at the actual accelerator pedal. The slow crank and exhaust could be separate issues. Get the alternator tested it might not be supplying enough charge to the battery. Some vehicle OBD systems need to be checked when you fit a new battery. As a battery ages some electronic systems can adjust and compensate for that over time.
If the CAT had gone it would often flag up a O2 sensor fault as the CAT wouldn't be working correctly.
What do you mean by "exhaust noise have increased"? Does it sound louder, Engine's running faster, Sounds rough and uneven? Comment below and I'll try to help you more.
tip
How to sound proof/increase the qualitly of the music in your car.
Most Car/Audio enthusiast have this problem: how to keep you music in your car while keeping the road noises out. And although it may seem like a complex problem, there are a few simple steps you can take to make your music sound better while keeping more of it in the car.
Now before we get started, I just want to say that every car is different. Each car will have different trouble spots that require different methods of treatment. Some of the accessories that i suggest can be expensive and alternatives that i talk about can be used for smaller price tag.
First, let us talk about sound quality. How would you define the quality of your sound? Most cars will have a standard speaker set that are made of low quality material that tends to distort at high powers. My first suggestion would be to replace your factory speakers. New sets of speakers can start at around $50 at Crutchfield.com and will greatly increase the sound quality of your car. Next, if you have basic upgrade speakers and use them in conjunction with a sub and amp, you may find that your cabin speakers may distort when the volume gets loud. You sub will sound great because it is designed to handle the power, but your cabin speakers may not have been. If you find they are distorting sound, try adding a pair of Bass Blockers. They sell for about $20 per pair. Make sure you find ones that match your speaker size as to provide the perfect bass cut off for best sound. If you want to start throwing out the big bucks and really start pumping the volume, invest in a nice head unit(CD player) and equalizer. A good head unit will have every thing you need to play great music. It will send the sounds to the right speakers so to limit distortion, etc. An equalizer will allow you to create the perfect sound for your taste by allowing you to adjust the decibel slopes for different frequencies.
Second, lets talk about vibrations. One of the worst things to have happen is to invest a large amount of hard earned money into a killer system, then when it is installed, the car rattles like no tomorrow and as a result all of the music is distorted. In cases like this, sound proofing material like Dynamat may be used. Dynamat is a thin rubber like material that bonds to the metal surfaces in your car so that they will not resonate/vibrate. Sound proofing the entire car with Dynamat would end nearly every vibration problem you may have. The only problem is that Dynamat cost on average $10 per square foot or $100 per 10 square feet. I would recommend using a different material. I used a roofing material call Quick Roof which was designed to seal holes in roofs. However, it does a comparable job to Dynamat and only cost about $15 per 10 square feet. That's $75 less than Dynamat. If you decide to sound proof your car, key starting places would be the doors and trunk. If you still have problems after this, try and seek them out by turning up you volume and standing out side of the car. To install Dynamat or Quick Roof, take off all panels until you see the bare metal of the car frame. Measure out the amount of material you will need, then cut peel and stick. Its that simple.
For Car/Audio Enthusiasts, sound quality is a key part in their everyday ride. You can invest hundreds of dollars into a nice system and not have perfect quality. If you have trouble with quality in your car, try some of the tips above. And although every part may not help out in your car, some parts might. Just remember what your goal is and remember that good sound quality is in your reach. Cheers to sick audio system. BrownyMan
I turned the key to the "on" position and listened to music while washing my 2011 MKZ. The music stopped and now the car will not start. No lights, nothing. There is a constant chirping sound under
Hook a charger up overnight, or try the jumper cables again. Make sure they are connected to the matching terminals. Check to see if anything has power without starting the car. Lights or radio working with key in the ACC position? If not, something has killed power from the battery- maybe a main fuse or a power distribution relay. Make sure the cables/connections aren't corroded at the battery posts.
2002 impala front end noise when accelerating/decelerating
Black the rear wheels, put the car in neutral with the parking brake on, jack up the front end and spin the tires. Once you locate the source of the noise, you can pull the tire off and check the brake pads and rotors.
Alarm seems to work; been checked at Toyota but they say siren is broken and say it's a common fault. But everything else seems to work - you can hear the relay clicking; lights flash.
What is actually the problem, "Actually seems to work", what doesn't work.
If Toyota are on about the 9volt battery back up siren then the main siren may be working fine, but that might not be. Most cars especially Vauxhalls have a 9volt battery back up siren, so if someone tries stealing you motor and they disconnect the battery the 9volt battery will keep the siren going off.
2answers
PUGEOT 306 SOUNDS LIKE A TRAIN/MOTORBIKE WHEN SLOWING DOWN
check the exhaust if the cat converter has let go these cars get very noisy you can check the cat by banging on it and checking to see if it rattles if it rattles it is no good.
Anti lock brake system
If the light is not on it may not be the ABS that is pulsating on slow braking but it may be that your have warped brake rotors, even if the rotors were replaced with the pads the new ones may be warped already, we always check new rotors on a brake lathe before installing them because we have seen this happen many times
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
