Music Logo
Justin Johnson Posted on Nov 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Get a hum out of the speakers with or without music
Can remove the speaker wires and it will quit. when you hook them back up the ground and the blue wire the hum is little when you hook the red and all 3 are hooked up the hum is louder. there is no difference witch wire is hooked up first.
Jerry Kramer
Level 3:
  • The Master 3,933 Answers
  • Posted on Nov 28, 2016
Jerry Kramer
The Master
Level 3:
Answers
3933
Questions
Helped
882429
Points
12076
This s a ground issue or your driver board has a bad component on it which can be replaced with a new one if you can find it. Look for burn marks.
3answers
What would cause a buzz in speakers?
There are many causes of buzz, so it should be checked step by step :
- Bad connection on the input connector, or cord.
- Amplifier, basically have the block diagram like this. View image.25850665-l1qpqmriditabltrjczr2eku-2-0.jpg
If in one block damage, buzz can be heard.In the amplifier.
Generally occurs in the PSU and / or power amplifiers.
Fix it to the experts,because it requires a good knowledge of electronics.
Blown speaker cone, does not cause a buzz.
Short circuit along the wires supplying the audio, it will not cause any sound in the speakers, including the sound of music.
Try also, disconnect the input connector, whether the buzz is still audible. If after the input connector is removed, the buzz disappears, the possibility of buzz came from another device before the amplifier.
1960 b cab not working
Open the cabinet (remove back panel). Either a wire came loose or one of those 2 speakers is blown.
Mixing board hum
AC hum comes from poor grounding of components.
Jun 21, 2017 • Music
2answers
Speaker humms only. what causes that?
Incorrect connections or volume settings.
• In powering up, mixer first then amp
• In turning off , amp first then mixer
If hum still persist, without the mixer connected
then speaker amp may need servicing.
On my peavey pro 15 neo speakers i don't know which wire is for what. What is the black, red, blue and yellow wires for?
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
I have a b415 dsp speaker that I pulled apart due to a rattle in the driver. I need to confirm the correct wire color to the speakers. I believe the red and black went to the driver and the blue and yellow...
Way to find out: The minus speaker leads go to ground at the amp and therefore are electricaally connected together... just use an ohmmeter to find which two wires are tied together and connect those to the minus leads of the speakers.
The small opening that the speaker wire plugs into has fallen back into the speaker. I can't get the plastic cover off the speaker to put it back in place.
The grill on these is hard rto dislodge.
There are a couple little screws to remove. Then you have to be fairly aggressive to get the lip of the screen dislodged. start at the center of the SHORT edges and pry under in the middle. The edge of the screen goes into a grove with rubber on the side.
Note, some of these MAY have adequate access by removing the socket where the unit can set on a pole.
You MAY be able to manuever the plug and possibly lockwaser into place. Use a stiff wire with a small bent hook to capture the plug and pull i back through.
Buzzing sound coming from the speaker at certain frequencies. more so when the bass is cranked. do i have to replace the speaker? or could it just be loose??
That is happening because your grounds went bad. Without grounds, then the amp will produce a buzzing sound. I would replace the input wire, that is probably the problem
2helpful
2answers
Generates buzzing noise even when only cable is connected to it. No cable - no noise.
If you are saying that you are plugging a guitar cord into an input on an amp without the guitar on the other end and you are getting a hum or buzz with the volume turned up ; that is normal. If you are getting the same results with a guitar plugged in it means the ground wire to your output jack on your guitar is broken. Check your cord with a volt ohm meter for continuity on the tip on one end to the tip on the other end. Do this for the sleeve on one end to the other. If you were getting the buzz without a cable it would mean that your input jack in your amp has a broken ground connection. Hope this helps.
Top The Music Experts
vince
NOEL
NOEL
Thomas Perkins
Thomas Perkins
Are you a The Music Expert? Answer questions, earn points and help others
