SOURCE: panasonic kx-t7730
Hi this is normally a programmable control, operating only when the power is ON,...so try to disconnect the power and operate it
or else, reprogram it by using the manual...
http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
SOURCE: Panasonic KX-T7730 does this phone have answer machine?
try using the call forwarding feature, you can forward it to your cellphone.
SOURCE: FWD/DND - PANASONIC KX-T7130
Don't laugh. Push the button and read the display. It will either unset DND or CF :-).
The 7100 command is part of the sequence to cancel those features on most phone systems and 790 or 79# will reset the extension. Of course it may be different if you have a TDA or TAW box (*7100) or a KX-T xxx10 system.
Carl
SOURCE: Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Testimonial: "Thanks Heaps Buddy"
