SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
SOURCE: How do you thread a SInger Sewing machine 2623
hi! there,
you can show some actual bobbins winder and threading go to internet explorer and type the address of "www.youtube.com" then on search type "sewing machine".there is a slide show for sewing instruction.just click the slot and it play the video showing what you want.regards don' t forget to rate me.
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
SOURCE: how to thread the bobbin on a singer simple sewing machine
Drop-in bobbin: Note: thread must change direction when entering bobbin shuttle notch. Usually bobbin will turn counter-clockwise when threaded properly.
1. hold bobbin so that the tail of thread is facing to left.
2. drop bobbin into bobbin shuttle.
3. pull thread toward you.
4. guide thread into notch and pull to left so that slot engages thread.
5. pull thread diagonally across shuttle toward back of machine.
6. draw bobbin thread up through needle plate with threaded needle.
SOURCE: i have a singer simple sewing machine and when i
Sounds like your feed dogs are in the down position. Make sure they are in position "A" (see picture)
Also, make sure your length dial is set to a medium setting (Usually 1.5 - 3)
