Brand name- canon product- 8mm video camcoder. ES600A
SOURCE: Message reads eject. won't eject
My camera did the exact same thing. I called Canon tech support and they advised to unplug power cord, remove large main battery, and remove smallbackup battery. The small back up battery is under a small door under the main backup battery. With everything disconnected, turn camera to "camera" and then to "vcr" and then to off. Wait a few seconds. Put everything back together and try to eject again. The tech said that resets all the mechanical parts. However, it did not work for me. They now want me to send it to them for a paid repair. I have done some research on the internet and this is a VERY commom problem and it usually costs about $150 to correct via Cannon. Many times the problem occurs again. I am very very frustrated. I pulled my camera out last night to get it ready as my wife is 9months into her pregnancy. Now, I have to send my camera away for 5-9 days. Really really upset.
SOURCE: dark screen on my video-camera Canon MV700i
I have the same problem, it appears that this camera is one of many cameras that have problems with the CCD (image sensor) have a look at this site for more info www.imaging-resource.com/badccds.html
I hadn't used mine for about 9 months, when I went to use it the screen was black with a bit of flicker. Canon are still fixing them if you're from the UK have a peep here - https://self-service.canon-europe.com/uk/pages/
Hope that helps
SOURCE: Cassate tape will not eject from my Canon ZR85 Mini DV Digital Camcorder
I found a temporary solution for this problem. When the tray with the cassette tape comes out remove the battery so that the tray will not go inside again. Now on top of the tray it will be written as "PRESS" just adjucent to it you can see a spring connected to the tray just press the string down wards and the tray opens and you can replace the battery. Hope this can help.
SOURCE: canon elura 90: won't load tapes
Actueally the loading section of the camera is mechanically unstable.And it needs mechanical adjustment.A sensor is present in its loading section that provide information of the presence of the tape in this section,When the mech. get unstable the sensor disfunctons.
Therefore,In short,Your camera needs mechanical adjustment.For this please contact any expert nearby to solve this.
Thanks for using fixya.
