Get foot of fuel line and insert into tank - bring it out and attach the filter - then draw it back it in with filter attached - cut off excess line and attach to carb input .
Diaphrams can be tricky sometimes...seating can be irritating. If carb disassembled and cleaned out...might have to check adjustments. Make sure screw didn't get loose. I had one do that before when governor broke.
If the carb has the "fixed" throttle control. Find the governor control lever with the small, long coiled spring attatched to it in the middle. It may be hooked to a metal tab that is on the back carburetor bolt. Bend the tab to your left to increase set speed or to the right (towards governor lever) to decrease.
I think that model may use the Tecumseh engine and carburetor application. Here is a diagram of what your machine (carb/choke and governor) should look like.
the solid wire link goes from the top hole in the governor rod to the carb and the spring goes from the lower hole on the rod to the throttle plate where the cable attaches
>>Send me the Make, Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you.
However, this File may Help.
**The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and the Other End of this Spring Attaches to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
