Kenwood Tt756sl 2-slice Radio Toaster With Fm Radio Logo
w
wendy Posted on Sep 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my radio not work in my kenwood TT756sl radio toaster, how do i fix it
Why does my radio in my kenwood toaster not work, there is no static or anything, do not hear any station
David Littlefield
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 136 Answers
  • Posted on Sep 09, 2016
David Littlefield
Expert
Level 2:
New Friend:
Greenhorn:
Answers
136
Questions
Helped
35763
Points
355
May have fuse blown, check fuses. Antenna may be disconnected.
Radio wiring may have come loose on back of stereo. Check all.
I have a Kenwood Protalk LT radio. Can hear others speaking clearly but they can not hear me. When press PTT and speak, red light goes on but no one can hear me. I have reset it but no luck fixing
Try opening it up carefully and checking for lose connections, especially the microphone. On second thought most radio communication devices don't allow you to do that so it may be difficult. To test and see if it's the microphone and not the transmitter circuit listen to another radio while you press the button if you hear static or a small pop that means it should be an easy fix if you can get inside. Also what kind of things have you tried already?
My KSC-35S UHF radio has constant background static,can it be squelched ?
Your Kenwood radio has programmable squelch. It is accessible through the software. However, if the squelch knob (pot) has been broken, it must be fixed or replaced. Move the control knobs back and forth, do either move more than say 1/16 of an inch? If so, they likely broke inside. You could open the radio, resolder the switch, which I called a pot and see if that works. If not, take it to a dealer or sadly, buy another radio.
Have a Kenwood TK-2200 that transmits just fine but does not receive. When powered up the white noise/static is constant. Any fix for this?
Many times static/white noise is a sign of a bad or low battery. You might try trading the battery with a known good unit to see if the problem goes away. Also, you may want to check your antenna, trade it with a known good antenna and see if it is the issue. Beyond this your radio would need to be looked at by a repair tech.
Best regards.
Kenwood tk3317 has stun on screen
At some point a STUN signal was sent to the radio possibly because it was STOLEN. The owner/agency/company or radio shop thought this was necessary because of security or malicious interference to the system. It will need the Kenwood program cable and software to fix it. Perhaps a radio shop can advise you and determine the status of the radio??
1helpful
I have a kenwood toaster it keeps popping up every 2seconds or less what could be wrong
It could be your browning control is not working or it needs to be moved to a darker setting.
I could not find the instructions for your specific model but in order to achieve uniform browning it is recommended you wait a minimum of 30 seconds between each toasting to allow the control to automatically reset. This could be the problem if the first cycle of toasting completes correctly; you need to wait the minimum 30 seconds before starting a second cycle.
If the product is less than a year old and under certain condition Kenwood will replace.
Contact information: http://www.kenwoodworld.com/uk/Customer-Service/
1997 Explorer Sport no sound issue
sounds like a bad radio install or radio is bad
1helpful
2answers
Paula Deen toaster egg poacher caught on fire
The same thing happened to me today and I've been searching the internet for other complaints. It happened exactly as you said, I heard a buzzing noise and went to see what it was and it was the toaster- smoke started to come out from the top. Please report your experience to the CPSC! http://www.cpsc.gov/index.html This thing needs to be recalled!
1helpful
Kenwood KVT-715 Radio not working
I would be willing to bet you have a 8v regulator circuit failure in hideaway Box. I have seen many of these units where a resistor opens and causes 12v instead of 8v to appear at tuner and a few other IC's. Usually But not always destroys tuner.
[email protected] if there are questions
Signal Interruptions - Static
I hope that you have had this unit for a while because it has been out of date for quite some time. I had this unit as well and furtunately the problems exsisted while under warrenty and I was able to get it fixed. Version 2 seemed to be better, the (A2). Sorry for the info, but vA1 was a bad unit if you ask me.
Top Kenwood Kitchen Appliances - Others Experts
ADMIN Andrew
ADMIN Andrew
David Littlefield
john h
Are you a Kenwood Kitchen Appliances - Other Expert? Answer questions, earn points and help others
