Televison & Video Logo
Johnnie Dee Posted on Sep 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix my LG Smart Tv that has sound but no picture?
Led smart tv only 3 years old has sound but no picture I changed the power/led board but this did not resolve the problem any suggestions would be appreciated
Electro Med Services
Level 3:
  • LG Master 6,694 Answers
  • Posted on Sep 19, 2016
LG Master
Level 3:
Answers
6694
Questions
Helped
1872737
Points
21433
The tcon board or the LCD panel is faulty . Can confirm by replacing the TCON Board .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
2answers
43LG Smart TV, got sound but no picture, ??.
Backlight is dead, probably a bad LED strip (s). Unless you can fix it yourself, a new TV is probably going to be cheaper.
LG 55LN5700 LED TV. Screen went black, audio works. Flashlight test, able to see pic moving. Replaced LED strips & pwr board. Try turn on, LEDs blink 1x and red light flashes 3x. Let it sit 8hr
Replace the jack wires going to the LED strips. Or look for the one bad jack wire going to the LED's and fix it. Use a volt meter on ohms to find the bad wire.
My LG 55 inch smart tv has no picture. I can see the picture with a flashlight. And the voltage seems good on the LED. What might be the problem?
hi check the led driver board for dry joints, what is the voltage you tested, my guess is the led in the panel has shorted out, thanks
shaun
2answers
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
1helpful
3answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
Here is what to check when your TV is turned on, power light is ON, but no picture is seen or sound is heard:
1 - Be sure the component you are using (Xbox, Cable, SAT, ROKU) is turned ON.
2 - Check to be sure all cable and cords are securely connected to the TV inputs and component outputs.
3 - Make sure you are on the correct input as some TV's will show a black screen if there is nothing connected to that input.
4 - Unplug the input you are trying to use from the TV (such as an HDMI Cable) and plug it back in.
5 - Check for signs of damage on all cords and cables from the TV to all components.
6 - Make sure the TV is not in ENERGY SAVE MODE, press the button on the remote control to go back to normal mode.
7 - Unplug the TV for 10 minutes to see if there was a temporary one time issue with the TV.
8 - Disconnect the TV from power for 2 minutes, then when plugging it back in PRESS AND HOLD THE POWER BUTTON ON THE TV FOR 10 to 20 SECONDS to try and force the TV to reset.
9 - If after checking all these different issues, you may have a Faulty Power Supply Board, A Bad Capacitor on the Power Supply Board, Loose Wire Harness, or Loose Ribbon Connector in the TV itself.
10 - Most likely when a TV has the power light ON but NO PICTURE and NO SOUND, it is the Power Supply Board that has failed.
BTW, here are solutions for you to play iTunes movies on Samsung smart TV
The cause of problem with an LG LED smart tv
LG TV 3 blink code is due to bad power supply or LED lamps in the panel. If you have technical skills of soldering, physically check and replace if you found bulging capacitors in the power supply. If PSU is working, check LED back light strips with LED tester and replace faulty LED back light strip.
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
