You need to determine what's "running". Here's why: There are three things that must be working to extract water. The
'coil' (a finned metal part that needs air to flow across its surface) may be filled
with dust and obstructions, so no air can move...then no water. There is a
blower motor that must move the air. If it is seized up and not blowing
air...very little or no water. The compressor creates condensation from
air moving across the coil (like the moisture than forms on an ice filled
glass on a humid day) to extract the water from the air. If it's not
working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not
working. If it's real hot air, and the humidifier keeps cycling on and
off quickly, the coil is dirty. Those are the 3 things that need to be
working.
SOURCE: Our 50 pint 54501 Kenmore
There can be many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
