Bought a flashlight and it works well, as your reference
MALLCROWN Tactical LED Flashlight 1200 lumen Adjustable Light Lamp with...
Maureen, Coleman Graphite Flashlight replace batteries. Remove bottom cap, it will be on tight, if you do not have good strength in your hands use a pair of pliers or channel locks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change the batteries in Mag Lite
Hello. According to Gerber Blades, the correct way to remove and replace the battery would be to unscrew the end cap all the way. The battery will then fall away allowing for a new battery insertion. Hope this helps.
