check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
If the remote control has a SAP button, pressing it should cycle through the choices. Keep pressing it until you reach OFF. (That's probably how it got turned on. It's easy to hit a button and not know it.) If the remote doesn't have SAP button, adjust the settings through the set's setup menu. If you are using a cable box, make sure it doesn't have a SAP setting that has gotten turned on.
SAP is short for "second audio program" and is a way to send a second audio track along with the main one. In many areas stations use SAP to provide Spanish or other language sound for movies and other programs. If you have SAP turned on you don't know it until you tune to a channel where it's being used, and then you hear the other sound. Just turn SAP off using the remote control or TV menu.
SP means Standard Play. Generally that is the Normal speed at which a VCR Records or Plays back a tape. SP is automatic, as it is the Standard setting. If you wish to record more picture than the normal 120 mins on a tape, then you choose LP (Lond Play) oe EP (Extended Play).
Do you have the original remote? it will look like the one here:http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=B27TF680&brand_pn=RCA_B27TF680&mode=large&uid=11758883061400 If you do not have the original remote you will not be able to switch off the SAP setting, without it as there is a button that controls the sound. when this button is pressed you see where to turn off the SAP setting. Good Luck
