Lands Phones Logo
B
Bhagya Posted on Jul 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to edit speed dial feature KX-DT333 - Panasonic Lands Phones
Alan Timperley
Level 2:
Sniper:
  • Expert 91 Answers
  • Posted on Jul 23, 2016
Alan Timperley
Expert
Level 2:
Sniper:
Answers
91
Questions
Helped
71859
Points
405
To Program:
Lift handset. Press * 3 0 , then enter the desired 2-digit code (00-09), enter the line access code (generally “9”) followed by the telephone number, then #.
To Use:
Lift handset. Press AUTO DIAL/STORE * plus the 2-digit code (00-09).
To Use System speed Dial:
Lift handset. Press AUTO DIAL/STORE plus 3-digit (000 - 999)
The User Guide can be found at the link below. Hopefully this helps.
http://www.manualslib.com/manual/853264/Panasonic-Kx-Dt333.html
5 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Sep 03, 2009
SOURCE: Panasonic KX-T7730 Speed Dials - Please Help!
So I guess that means you're not programming SYSTEM speed dial numbers. Those are programmed from the system manager or operator's station. Personal speed dials are 1-0 and are programmed per set.
Carl
Anonymous
  • 113 Answers
  • Posted on Mar 24, 2010
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Aug 14, 2010
SOURCE: Does model KX-TG7432 have a speed dial feature?
Speed dial as in dialing a stored number? Look at Shared Phonebook in the manual. http://service.us.panasonic.com/OPERMANPDF/KXTG7431-MUL.PDF
Carl
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Sep 25, 2010
SOURCE: how do I change name
From the phone connected to Jack 01 or the authorized phone (generally 101) press PROG and dial **1234 Dial 004 and ENTER and dial the ext number of the phone you want to change Use the keypad to enter the name (you have Upper and Lowercase letters) and the arrow key to step to the next character. When you finish, press STORE.
Carl
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Dec 22, 2010
SOURCE: need to change the answering machine message on my
I dial 500 and follow the prompts.
Carl
Panasonic KX-DT333: The switchboard/directory isn't showing 'busy' lines lit up red after recently re-programming phones.
If the busy lines on your Panasonic KX-DT333 switchboard/directory are not lighting up in red after re-programming the phones, it's possible that the programming settings related to the busy line indication were inadvertently modified. Here are a few steps you can try to bring back the feature:
  1. Verify quick dial settings: Double-check the quick dial settings on the phones that are not displaying the busy lines. Make sure that the busy line appearance is correctly assigned to the corresponding quick dial buttons. You can refer to the phone's user manual or programming guide for instructions on how to assign busy line appearances.
  2. Check programming options: Access the programming mode of your Panasonic KX-DT333 system. Look for settings related to busy line indication or busy lamp fields (BLF). Ensure that the appropriate options are enabled or configured to display the busy lines as red.
  3. Restart or reset the system: Try restarting the switchboard or resetting it to its factory default settings. This can help restore any configuration settings that might have been changed during the re-programming process. Be aware that resetting the system will erase all previous programming, so it's crucial to have a backup of your settings if necessary.
  4. Consult the user manual or contact support: If you're still experiencing difficulties, refer to the user manual or programming guide for your Panasonic KX-DT333 system. These resources should provide detailed instructions on how to configure the busy line indication feature. If needed, you can also reach out to Panasonic customer support for further assistance.
Remember to exercise caution when accessing the programming mode or making changes to your system's settings. If you're unsure about any steps or if you're uncomfortable with the process, it's advisable to consult a professional technician or contact Panasonic support for guidance.
KX-DT333 night mode message bank is not working
The problem you're describing with the KX-DT333 night mode message bank not working could be caused by several factors. Here are a few steps you can try to troubleshoot the problem:
  1. Check the night mode settings: Make sure that the night mode settings are configured correctly and that the message bank feature is enabled.
  2. Check the message bank settings: Make sure that the message bank settings are correct and that the message bank is not full or locked.
  3. Check the phone's firmware: Make sure that the phone's firmware is up-to-date and that there are no glitches or errors.
  4. Check the phone's connection: Make sure that the phone is properly connected to the telephone line and that there are no loose or damaged connections.
  5. Consult the manual: Consult the manual for specific troubleshoot and service information for your KX-DT333 model
KX-T7630 How do I edit the system speed dial numbers on this PANASONIC phone? I cannot find anything online in the manual. I can only find the personal speed dial options for storing numbers.
There doesn't appear to be a way. Sometimes on multi-phone business systems, a technician can connect a laptop with dealer software and make changes or edits that a user can't.
If that particular number needs to be at Number 1, you would have to delete them all and reprogram them all again.
http://www.voicesonic.com/panasonic/manuals/KX-T76xx_User_Guides/KX-T7630_User_Guide.pdf
How to make a recorded greeting on panasonic kx-dt333 phone system.
http://www.ek-king.com.tw/KX-DT333.pdf
http://eng-ca.faq.panasonic.com/app/answers/detail/a_id/20743/~/how-do-i-record-my-own-greeting-message-for-my-answering-machine%3F
Edit speed dial KX-DT333
http://www.pacificbusinesssystems.com/docs/KXDT333.pdf
How to turn on voicemail feature when busy on other line
Try out this PDF it's a Manual for that model
https://www.voicesonic.com/panasonic/manuals/KX-DT300/KX-DT333-343-346_Quick_Refernce_Guide.pdf
How do i program speed dail #'s on Panasonic KX-dt333?
A system speed dial or using a button on the phone as a one touch speed dial?
If a button on the phone: press program, press the button you want to use, 9, the number, enter
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
