How do you stop scraping sound of shower door on KOHLER K-706015-L-MX Levity Bypass Shower Door with Towel Bar and 1/4-Inch Crystal Clear Glass in Matte Nickel
One door slides great, other is like nails on a chalkboard, tried adjusting for an hour
The chanel at the bottom of the door that guides the doors has drain slits in it make sure the are not plunged up and also make sure the door are not to high off that chanel.
I know it's is going to be a tedious process to remove,clean, and replace bottom piece but I think that is what you need to do. Sorry I don't have a easy fix for you. Good luck and thank you.
Please clarify - you said it's a pivoting door but also said it doesn't slide smoothly - can't really do both at the same time. If it's a typical bypass sliding door then you should be able to make an adjustment to the hanging brackets on the offending door to raise it up off the track. If all else fails the header track can be raised thereby making the doors hang higher and off the track attached to the tub surround.
It's usually best to take the OUTSIDE door off in that case; and start from the INSIDE, then do the OUTSIDE. The track wheels MAY be reversed on IN/OUT, so watch how they hang in the track. When everything is off, it's a great time to scrub out all the "yuck" that grows down in there. Once that's all cleaned out, rehang the INSIDE door and get it going smoothly, then the OUTSIDE door. You're all set then.
This is not a specialty store. This is a general internet forum. And people who answer are scattered across the planet. Try checking for a local plumbing store and call them.
curved cut glass will not always be the exact dimensions though they may look identical there should be several set screws on both the door glass frame and the shower glass frame that can be loosened and reset to make the door fit and close and open more properly without seeing the showwer itself i can not tell you exactly where they are but they should be either visible or behind a facade piece of metal frame
