Model UN55FH6003F, have a picture that comes and goes (sometime have to hit it on the side), The picture appears to be very very dark went it goes can almost make out the picture on the screen. I always have clear sound. Looked at the three boards, only mark I can find appears to be a small black smug mark on the back of the power supply board. All other boards look good. What do u think????
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV? hope u get a answer from hitachi....and good luck
