Is it leaking out of drain valve -pressure relief valve or the body of the unit [rusted out ]first off if turned off service /inline valve and water still coming in need to replace valve also --as to other valves they are replaceable --if unit itself is leaking than replacement is needed
They wear out especially if they are older. You did not say what make and model it is but if there is water coming out the bottom it is time for a new unit. The leak is still happening because even though there is not supply pressure, gravity is pulling the water out the break in the liner.
SOURCE: The power vent blower on my hot water tank will not shut off.
If the blower continues after the end of the burn cycle it is the cool the heater down. Over running would indicate a defective end cycle temp relay.
Good Luck, Phil
SOURCE: Hot water heater leaking at the top valvue
I believe the problem you had with the pop off valve is a one time thing since you said you just installed the water h eater
The pop off valve is a pressure relief valve that is activated by build up in the tank from excessive pressure either through too much heat or pressure which works by pressing aginst a spring loaded valve
If you go to the whater heater and look at the valve ther is a handle on it take your hand (stand clear of valve opening) and slowly pull it you will see water start to come out
More than likely a new valve could have had a piece of debris in it or was partially open
re
If the heater was overheating the valve would stay open and you would see extremly hot water rushing out
I do not recommend that you replace the valve unless it continues
Good luck to you
SOURCE: hot water heater is leaking and making noise
Hit the disconnect and call a plumber. Sounds like your heating element or elements have gone bad and need to be replaced. also shut off the water. This is repairable, but it is HIGHLY recommened to have someone with expeirence in this kinda of problem fix it since you are messing with water and electricity. The repair should be no more then 200 dollars
SOURCE: leaking pressure relief valve
what is the water pressure on the cold side? You may need to install a pressure reducing valve at the water heater inlet to reduce inlet pressure and keep pop off valve from opening when not needed.
SOURCE: Rheem Warrior glass hot water tank odel
Hello, cracklin. Now that everyone has told you what it is, I wil tell you how to fixit, sense we are a fixit site.
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about hot waterheaters and possibly yours, from repair to trouble shooting it. http://home.howstuffworks.com/water-heater.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
