SOURCE: How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.
SOURCE: how to associate the av sound with the HD video out
DVI connections do not carry sound. The only feasible way to get sound from the PS3 is through a standard twin phono-phono lead (red & white RCA)
SOURCE: change av without remote
get a universal remote if i wer you it may solve it but they do cost a bit ... look on the bright side you can tune those to any tv in the world =)
SOURCE: changing the channel to av without a remote
I dont know if you tv has this sertting but click menu usally 4 times and it will bring u to a page wich might say channel or something else and u can chane the channel by using the volume buttoms this worked for me and i can put it onto av1 av2 av3 and av4
