20 Most Recent
Sanyo AVM-3259S TV Questions & Answers
SANYO TV MODEL CM20SP8S CHASSIS AC3-A20
try to fine tune your tv using the remote control, or, if you had knowleged in electronics adjust the sound IF transformer using a wood stick or plastic don't use a metal in adjusting the IF
Sanyo television-model-DS25530
have you treid the menu settings and looked at the rear for internal /external switch on the rear of set if yes to both possible audio ic.
Got a Sanyo DS25320 and
The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like Remotes.com to buy the tv original remote to use.
I have a mitsubishi tv
Return the univeral remote to the store,the codes that was provided for ur tv model on the univeral remote manual book,if doesn't work.It is impossible,u will get the codes,that will.Try website like Remotes.com to buy an original remote that was belong to ur tv.
