Dishwashers Logo
Sue Jeffries Posted on Jun 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bypassing softener when watering the lawn. Uses too much salt..can we turn off the water softener when we are watering the lawn and how do we do this.
Bill Boyd
Level 3:
Top Expert:
  • Dishwashers Master 53,816 Answers
  • Posted on Jun 19, 2016
Bill Boyd
Dishwashers Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11951014
Points
172802
Leave the setting on the water softener alone as it will become a tiresome exercise
place a "t" joiner in the water line before the softener with a tap on the outlet side to the softener and a tap on the outlet side to the lawn hose and fix your lawn hose to that
That way when you want to water the lawn adjust the taps so that the water softener is cut off and the hose is turned on
or when using the softener the tap is turned on and the hose is turned off
use ball valves ( 90 degree action)with a handle and the direction of the handle will determine the direction of water flow
  • ADMIN Andrew
    ADMIN Andrew Jun 19, 2016
    That is exactly what I was going to suggest Bill. Use the best quality ball valve shut offs you can find. They are more reliable and if possible, ones with a metal lever.
Kenmore Water Softener. It is using excessive salt?
Help here
Why a softener is using too much salt? Often the culprit is that higher than necessary concentrations of brine flow through the resin during regeneration, or the brine flows through for too long of a time period. In these cases, the excess salt just ends up wasted down the drain.
Is My Softener Wasting Salt? ' Water Treatment
tip
Water softener salt bridging
One of the most frequent problems with water softening systems is salt bridging in the salt/brine tank. There are several reasons for salt bridging to occur. This generally occurs when pellet type salts or potassium chloride is used to regenerate the water softening system. Pellet type salts contain binding agents that in turn give the salt a very starchy consistency when wet. As water evaporates in the brine tank the pellet salts partially dissolve, bind together and form a "salt bridge" in the tank. Potassium chloride (Kcl) acts in the same way. Excess water in the salt tank, with high salt levels, can also cause salt bridging. Improper softener brining and lack of proper brine refill will cause bridging to occur as well.
What is the best way to alleviate these problems?
1. When using pellet type salts or potassium chloride only keep the salt tank about 1/2 full. This prevents too much compaction of the salts and helps to prevent bridging. When using potassium chloride get the salt tank off the floor on a wooden platform to prevent wicking of moisture from concrete floors.
2. Use a high grade of salt. Most water treatment dealers use either
DuraCube or HardiCube water softener salts produced by Cargill Corp.
Cargill has a link to find dealers in your area.
https://saltapps.cargill.com/cargillsalt/product_locator_new.asp
Solar Salt is another option as the crystal structure is very hard and virtually impossible to bridge. This is also available from many Cargill salt dealers and in stores.
3. Let the salt tank run down to 80-100lbs of salt or potassium a couple times per year to help prevent buildup of dissolved salts in brine tank.
4. Yearly maintenance of the water treatment system helps also. Restrictions in the brining system (injector/eductor assembly) caused by sediment and oxidized iron buildup cause improper brining and too much water in salt tank during refill. Have this assembly cleaned yearly. Have the water tested to see if the water chemistry or usage have changed and adjustments to the system are necessary.
5. Avoid using rock salts to prevent buildup of sediment in brine tank (which causes service problems).
Practice these tips and you will have fewer water softener problems and more consistent quality softened water.
I wish you good water!
H2O Services
1helpful
The salt in the dishwasher compartment is flushed away in a single cylce
Salt is typically used in a dishwasher to regenerate the water softener. The water softener is a device that helps to remove hard water minerals, such as calcium and magnesium, from the water that is used in the dishwasher. When the water is soft, it can more easily remove food particles and stains from dishes, resulting in cleaner dishes. The salt that is used in the dishwasher is typically added to the water softener compartment and is used over time to regenerate the water softener.
If you are observing that the salt in the dishwasher compartment is being flushed away in a single cycle, it could be caused by a few different issues:
  1. Overfilling: If the water softener compartment is overfilled with salt, it can cause the salt to be washed away during the wash cycle.
  2. Leak: If the water softener compartment is not properly sealed, water can leak out and flush away the salt.
  3. Incorrect type of salt: If the wrong type of salt is being used, it may not be compatible with the water softener and can wash away during the wash cycle.
  4. Water pressure is too high: High water pressure can cause the salt to be washed away.
  5. Clogged filter: If the filter in the water softener compartment is clogged, it can cause the salt to be washed away.
It's important to consult the manual of the dishwasher to understand if this is a common issue or if the problem is specific to your dishwasher. If the problem persists, it is best to consult a professional for repair or maintenance.
Jan 12, 2023 • Dishwashers
1helpful
2answers
Break up salt in water softener
Hi Katie,
There are times when it may be necessary to break up the water softener salt in the salt tank. When a "Salt Bridge" occurs moisture has been drawn up into the salt and formed a crust on the water softener salt. When a salt bridge occurs there are two ways to correct it. You can lightly tap away at the salt bridge with a broom handle or stick until it dislodges and all falls down to the proper salt or water level. You can also pour about a gallon of hot water across the salt bridge to break it down. DO NOT poke the stick all the way to the bottom of the salt tank as this can potentially damage some parts of the salt tank. Frequently using some hot water and a stick will easily dislodge the salt bridge. Salt bridging is a common problem with water softeners and is usually caused by using pellet-type water softener salt and/or the water softener not working properly.
Using a better grade of water softener salts like Hardi Cube or Dura Cube salt will alleviate this problem. After fixing a salt bridge always manually regenerate your water softener two days in a row to assure you have soft water again.
May 16, 2022 • Dishwashers
1helpful
Woke up this morning to water as salty as sea water.
You have a water softener installed in your plumbing system? If you do then it has not completed its cycle. During the cycle it shuts off the soft water and uses salt to regenerate the beads in the system. When it has completed the process of salt injection, it is supposed to rinse out all the salt. For some reason this did not happen. The reason could be due to power failure, clock failure, valve failure etc.
Why is there water in salt reservoir when bypassing or is that normal?
There is always residual water left in a brine style water softener.
1helpful
When my water softener regions can I use it to water my lawn?
I live in the country and my water softener back flushes into the ditch via the sump pump and that doesn't seem to hurt anything-the water does have salt in it but it must not be enough to hurt anything-cheers Denny
Softener WG 844 needs flushing to remove dirt
If there is DIRT/SEDIMENT coming through system then you have a bigger problem. Well problems! Bypass the softener and run water into white bucket to see if it is coming from well. If so keep unit bypassed and call well man. The call Culligan to rebed softener.
RJ
My water softener uses too much salt.....its from clearwater
This could be several factors depending on the Softener model you have will depend on the type of adjustment needed to adjust the salt consumption. If the valve has a gallon counting control, it's possible the meter is set to a short number of gallons, example: set for 200 gallons instead of 2000....or if its a day wheel counter, it could be set to every day, instead of every 3rd day..there is also a "secret" salt setting located in the back of the power head...(the boxy looking thing on the top of the tank), which also could be set to 20lbs of salt instead of 6lbs....these are examples, and not suggestions.
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
