We are replacing the clutch and have reached the point of removing the starter, but we can't find a way to get to the top bolt other than removing the brain box. How do we disconnect the brain box without damaging it?
SOURCE: Removal of Rear Brake Drum on 2004 Chevy Aveo
1.Release parking brake.
2. Apply the brake pedal at least 10 times.
3. Raise and support vehicle with jack stands, etc.
4. Remove the tire and wheel assembly.
5. Remove the lock ring and the caulking nut from the spindle.
6. Remove the drum from the spindle.
Note: Pull the drum straight off the spindle.
There is an opening on the inside for adjusting the tension,It's under a rubber cap.You can use a screw driver to make the adjustment
SOURCE: Chevy S10 Pickup Starter. Removed the two bolts
Just changed a starter in a 94 S10 4x4. The only way to remove the starter was to take the passenger side exhaust manifold off and bring the starter out that way. Installation the same in reverse. Hope this helps. Don
SOURCE: Rear speakers for Chevy Aveo
you can access them from under the package tray inside your trunk compartment
SOURCE: 2004 chevy aveo cylinder head bolt torque how many
Step 1: 18 lb.-ft.
Step 2: additional 60 degrees.
Step 3: additional 60 degrees.
Step 4: additional 60 degrees.
Step 5: additional 10 degrees.
Each step involves starting at the center two bolts of the head and alternately tightening in a criss-cross pattern, ending with the bolts on the outer edge of the head.
SOURCE: how to remove starter from a 2005 chevy aveo
Please don't forget to rate....thank you:
The location of the starter
To install:
