20 Most Recent
Chevrolet 2004 Chevrolet Aveo Questions & Answers
How to change head gasket
That's a pretty big job, if you're not a mechanic.
in general (I've not done one on an Aveo)
1. detach intake and exhaust manifolds from head
2. remove sparkplugs and move all wiring aside
3. Remove cover from top
4. Guessing overhead cams, remove belt/chain
5. remove head bolts.
6. pull head. I used to have a special tool that threaded into plug holes and pressed down on head studs. Otherwise, we'd end up lifting the whole car by the head and beating on it to get the head off.
7. clean gasket debris off head and block.
8. If needed send head out to be milled to flat.
9. place head gasket, add head, and torque to specs.
and the rest of what you did to get it off, in reverse order.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
I have a Fisher 5
The E display indicates disc loading error.Due to inactivity the carousel loading trays rubber belt would have either become stiff or loose ( depending on which part of the world you live in ).So your loading action is not being completed due to your loose loading belt condition.
There are sensors ( small leaf switches ) which tell the micro controller if the tray has gone in completely and lifted the CD off the carousel tray, only after that the CD starts spinning for play operation. If this sequence does not complete the tray opens and closes by itself in some makes and model during power On
If you are up to it you can open the top cover and see the loading tray and beneath it is the loading belt.Your challenge is getting a replacement today of an old model.
