Just need to know how many watts cc-752 concept amp is that's all
SOURCE: concept cc752l how many watts
A easy way to tell how many watts an amp has is to look at the fuses on the amp itself eg. if it has one 10 amp fuse its probably a 100 watt amp, or say a 30 amp fuse would be around 300 watts. Most amps have more than one, so just add up the fuses and times it by 100.
SOURCE: i need to know how to wire a single 2 ohm sub to a
If your sub is 2ohm it's just left positive and right negative at the amp to the speaker. Hope this helps
SOURCE: Bridging CC-452 or CC-752 amps.
either will work fine, as long as it's a + from one channel and a - from the other.
SOURCE: what speakers
Hello enot99,
The CC-2502 is a bridgeable 2-channel amp. If you want to drive normal speakers in stereo, the best would be a good set of components with separate woofers, tweeters, and crossovers. They are available in many sizes from most car audio manufacturers. I'd begin by finding out what speakers fit the location where you intend to mount them. Then I'd browse the speaker selections in that size at www.crutchfield.com. You can also use the "outfit my car" feature to browse only the products that fit. Then select a pair that has a power range and impedance to match the amp: 250 watts RMS at 4ohms or 450 watts RMS at 2ohms.
If you want to use the amp in bridged mono mode to drive a subwoofer, again Crutchfield has a large selection of subs and some enclosures already fitted with subs (loaded). The amp claims 850 watts RMS into 4ohms bridged, so look for a sub that has a power handling rating of at least 850 watts and it needs to be 4ohms.
Hope this helps.
SOURCE: i need a rebuild kit for the concept cc-2502
lol, there is no rebuild kit for an amplifier. You will need to go to radio shack or an electronics store to get the replacement parts. Try this site
http://www.mcmelectronics.com/
