SOURCE: Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
SOURCE: model ds31520. I've had
Sorters -
Re-connect to me on the chat and we'll get this sorted. I'm really sorry - I got disconnected and the system would not allow me to reconnect to you. I have some ideas but chat would be easiest. If you don't want to chat, post a message here and I'll message back with some things to try.
BElectric.
Television system: NTSC-M
TV Standard
Closed Caption
System: §15.119/FCC
Channel coverage
VHF: 2 - 13
UHF: 14 - 69
CATV: 2 - 13, A - W,
W+1 - W+84,
A-5 - A-1, 5A
Tuning System: 181 channel
frequency synthesized
tuning system
Channel access: Direct access keyboard,
programmable
scan and up/down
Terminals
Antenna input: VHF/UHF/CATV
75 ohm unbalanced
(F-type)
Video input: RCA connector x 1
(1 x Front)
Audio input: RCA connector x 1
(1 x Front)
1 speaker
ELECTRICAL SPECIFICATIONS
Sound output: 1W, 8 ohm x 1
OTHER SPECIFICATIONS
Remote control: Digital encoded
infrared light system
Operating
temperature: 5°C to 40°C
(41°F - 104°F)
Power requirements: AC120V, 60Hz
Power consumption
(Maximum): 98W
Picture tube: 23"
Dimensions: H : 20-3/8" (518mm)
W: 22-13/16" (580mm)
D : 18-7/16" (469mm)
Weight: 55.1lbs. (25kg)
•Designs and specifications are subject to
change without notice and without our
legal obligation.
•If there is a discrepancy between languages,
